2016 F150 Global Windows
sethjamto
Vehicle: 2016 Ford F150 3.5 Ecoboost
Post by sethjamto » Tue May 09, 2017 9:29 pm
I've written several changes to my truck with success, but for some reason cannot get the Global Windows to work.
Right off the spreadsheet, this is what I've done, and I've verified the write several times.
Global Window Open/Close
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
After pressing lock/unlock on fob, press lock/unlock again and hold button for front windows to go up/down (instructions on using global windows from the spreadsheet - it flat out does not work though).
Any ideas?
2016 F150 3.5 Ecoboost Lariat FX4
millertime83
Vehicle: F150, 2.7, v6, 2017
Re: 2016 F150 Global Windows
Post by millertime83 » Thu May 11, 2017 2:02 am
I have the same issue. I will be following
Madcap
Vehicle: 2016 F150 5.0 4x4
Post by Madcap » Thu May 11, 2017 2:46 pm
millertime83 wrote:I have the same issue. I will be following
I think the problem with both of you is the timing of your key fob presses. Slow down a bit and try it. There is also a post/thread on another forum for this, I will have to look it up. Probably buried in the thread i sent seth to before
sethjamto
Post by sethjamto » Sat May 13, 2017 12:40 pm
I was thinking it my be the timing, so I've tried it a couple different ways with no luck. Maybe I'll try again. I'll go back and try and find the thread you sent me before and re-read it.
Madcap
Post by Madcap » Sat May 13, 2017 1:23 pm
Try this to close
1. Hit lock and release.
2. Hit lock and hold.
To open:
Hit unlock and release.
Hit unlock and hold for few seconds.
sethjamto
Post by sethjamto » Sun May 21, 2017 3:32 pm
Madcap wrote:Try this to close
To open:
That was it! Thanks!
Vycor
Vehicle: 2015 Ford F-150 V8
Post by Vycor » Fri Jun 02, 2017 10:25 pm
WELL! This sure is a real nifty feature! Is there a way to make the rear windows go up/down as well?
asims
Vehicle: 2015 Ford F150 XLT 5.0 V8
Post by asims » Sat Jul 08, 2017 11:36 pm
Not that I am aware of at this moment
Livnitup
Vehicle: 2016 F-150 Platinum 3.5L EB
Post by Livnitup » Sun Jul 09, 2017 5:08 pm
Vycor wrote:WELL! This sure is a real nifty feature! Is there a way to make the rear windows go up/down as well?
No, can't do the rear windows.
mct2green
Vehicle: 2016 f150 2.7l
Post by mct2green » Fri Oct 06, 2017 3:03 am
2016 F150 xlt. I cannot get global windows to work. Error when writing says bad data. Tried multiple times. Any advice?
straight from the spreadsheet
