FORScan release notes
Stesa1
Vehicle: Mazda CX-5, 2.2 Diesel, 175PS, 2013
Re: FORScan release notes
Post by Stesa1 » Fri Mar 18, 2016 7:59 am
Thank for your help.
before I choose the possibility to write you a debug log, i try again with new installation, an clear also the data cache at the android system.
Now it is working again and the REG_DIS PID is there. :D
Thank you again for your suggest help, very quick, very professional support. :)
jgrcevic
Vehicle: mazda 6, 2.0 105kw
Post by jgrcevic » Mon May 09, 2016 4:55 pm
Hi Forscan!
Is maybe a new beta version avalable?
I would like to test it if possible...
Thank's in advance
Post by FORScan » Tue May 10, 2016 4:55 am
What kind of function or bugfix do you expect (missing in latest official release)?
jgrcevic
Post by jgrcevic » Tue May 10, 2016 4:58 pm
Disabling seatbelt chime :)
FORScan v2.3.3 release notes
Post by FORScan » Wed Jul 27, 2016 1:18 am
This version has Central Configuration function added for many vehicles. It requires secondary boot loader (SBL) to be loaded before accessing the central configuration. These files are not a part of FORScan package and have to be downloaded and installed separately. There are 2 ways to do it:
1. Download necessary file directly from Ford Tech Service site
2. Download this archive that contains most popular SBL files and unzip it to Documents/CalibrationFiles folder.
If SBL file is not available, the following error will be displayed:
micky83
Vehicle: Ford Focus 1.6 TDCi 110cv FAP - 2009
Re: FORScan v2.3.3 release notes
Post by micky83 » Wed Jul 27, 2016 3:08 pm
FORScan wrote:This version has Central Configuration function added for many vehicles. It requires secondary boot loader (SBL) to be loaded before accessing the central configuration. These files are not a part of FORScan package and have to be downloaded and installed separately. There are 2 ways to do it:
What is the site Ford Tech Official Service ? To which address must refer ?
Of course, thanks in advance for the " Calibrations files " package and for the magnificent work of software development.
rioachim
Vehicle: Focus, 1.6 100CP, 2005
Post by rioachim » Thu Jul 28, 2016 7:49 am
MarcoGaspar
Vehicle: Ford Mondeo, 1.8tdci, 2008
Post by MarcoGaspar » Sun Sep 04, 2016 10:57 am
I get this error's:
(OK) [13:19:03.562] Central configuration (Main) has been started
(WARN) [13:19:03.593] Read configuration from primary module...
(WARN) [13:19:06.375] Loading SBL to primary module...
(WARN) [13:19:06.671] Loading block 1/4...
(WARN) [13:19:28.984] Loading block 2/4...
(WARN) [13:19:29.406] Loading block 3/4...
(WARN) [13:19:29.781] Loading block 4/4...
(OK) [13:19:30.406] SBL loaded successfully
(OK) [13:19:30.656] Read block #1
(OK) [13:19:30.828] Read block #2
(WARN) [13:19:31.078] Operation failed, retrying...
(WARN) [13:19:31.375] Operation failed, retrying...
(WARN) [13:19:31.671] Operation failed, retrying...
(WARN) [13:19:31.968] Operation failed, retrying...
(WARN) [13:19:32.265] Operation failed, retrying...
(ERR) [13:19:32.406] Reading block 3 failed
(ERR) [13:19:32.437] Service procedure has been interrupted
Ford Mondeo MK4
MarcoGaspar
Post by MarcoGaspar » Sat Oct 08, 2016 10:28 am
MarcoGaspar wrote:I get this error's:
Ford Mondeo MK4
Any help???
DeclanJewell
Vehicle: FIESTAST180
Post by DeclanJewell » Wed Oct 12, 2016 11:32 am
I am trying to turn off the change up gear indicator on a MK3 Focus ST facelift 2015. I am getting an error message "Loading SBL to primary module, Error opening file: F1FT-14C097-AA Please copy calibration file to :.......
Can anybody help me here in accessing the config files?
Cheers in advance
