FORScan release notes
NathanSA
Vehicle: 2017 Ford Ranger PX2 XLS 2.2
Re: FORScan v2.1.23 release notes
Post by NathanSA »
FORScan wrote:
Thu Nov 20, 2014 1:54 pm
+ Service function "Reset pilot injection quantity learned values" for:
Galaxy 1.6/2.0 TDCi(Euro V) 2010 model year
Mondeo Mk4 1.6/2.0 TDCi(Euro V) 2007-2011 model year
Kuga 2.0 TDCi TDCi Euro V 2008-2013 model year
Focus Mk3/CMax 1.6/2.0 TDCi 2011 model year
Ford Ranger 2.2/3.2 TDCi 2011 model year
Transit 2.2/3.2 TDCi(Euro V) 2006-2014 model year
Transit Connect 1.6 TDCi (Euro V/Eco III) 2014 model year
Mazda 3 Mk2 1.6 Y6 2009 model year
Mazda 5 Mk3 1.6 Y6 2010 model year
Mazda B-series 2.2/3.2 TDCi 2011 model year
This function was added as a result of investigations on this Focus Mk3 1.6 TDCi problem:
http://forscan.org/forum/viewtopic.php?f=5&t=468
Modern diesel engines with Common Rail have so called Pilot Injection function that means injecting small volume of fuel right before the main injection event. This reduces combustion noise and improves the work. The fuel quantity of the pilot injection depends on many conditions (mode of work, wear etc), so it is a subject of self learning process. In some cases these learned data have to be reset and re-initialized (for example, if one or several injectors are replaced). Some powertrain control modules are able to calculate initial values for pilot injection quantity based on injectors' C2I codes (this is why it is so important to program new injectors in PCM). But some PCMs also require additional procedures to learn new values. For some reason, the "Reset All Adaptations" sevice function on Focus Mk3 seems to be performing incorrect initalization of these values, so this function was added to solve the problem, first of all.
I see the "Reset pilot injection quantity learned values" was implemented here for the Ranger 2.2. Is there meant to be a process followed?
I just get a wait 5sec...then a prompt to turn IGN off, then 100% indicated...
Is the engine meant to be running at the time?
Some help would be great.
david.michell
Vehicle: everest 3.2l diesel 2017
Re: FORScan release notes
Post by david.michell »
HI i just downloaded the new version FORScan Lite v1.5.3 for iPhone now it wont read TRansmission temperatures for Ford Everest 2017 3.2 previously had no dramas under the BdyCM TFT Tempt use to appear now it doesnt? I’m just getting a lot of “BdyCM.TIC-01_OOSYNC-TIC#1 Out of Sync messages? Please help!!! :cry: :cry:
npuBaJIT
Vehicle: Mazda CX5 2,5 GT
Post by npuBaJIT »
Dear Forscan, Happy New Year. Today tried version 2.3.27 beta and Obdlink MX+, but as soon as forscan is finishing scanning and connecting to the last module - forscan programm just shuts down. On russian forum found the same problem. Tomorrow will try older version.
Paul_13
Vehicle: Mazda MX5 with RX8 231 engine
Post by Paul_13 »
npuBaJIT wrote:
Sun Dec 29, 2019 4:59 pm
I'm getting the same issue. Forscan unexpectedly closes. Bit disappointed as I was looking forward to seeing any changes
Edit: this is the error code.
The instruction at 0x004f96ac referenced memory at 0x000003c. The memory could not be read.
Click OK to terminate
npuBaJIT
Post by npuBaJIT »
With older version of Forscan 2.3.26 and OBDLink MX+ on Mazda CX5 2018 everything is working, with new version of Forscan 2.3.27 - forscan shuts down after full scanning of the car is finished.
FORScan2.4.3/Els27v4/UCDSv4/Elitebook840G6/Win10pro
jdaird
Vehicle: 2017 F-350 DRW Ford 6.7 Powerstroke
Post by jdaird »
With the latest version of Forscan is the manipulation of the hexadecimal code gone now? Is it all just point and click now?
If so, is there a list of what can be found under which modules?
2017 F-350
TIA
ithinkicanbus
Vehicle: F550 6.4 and 6.7 '15 '08
Post by ithinkicanbus »
Anyone else have problems downloading 2.3.29 ? I get a movefile error code 5, sometimes it will download, but the shortcut will disappear along with files in start menu. Thanks.
theviking
Vehicle: 2012 Lincoln MKZ AWD V-6
Post by theviking »
Does each new version of Forscan contain "ALL" of all the previous versions capabilities, or does a person need to search out the version that contains their specific vehicles applications? Thank you for a response.
theviking wrote:
Wed Apr 29, 2020 1:34 pm
new is better :D
2.3.32 beta, 2020-04-15
Changes History
+ Added feature
* Improved/changed feature
- Bug fixed/removed feature
