Mustang S197 2005-2009 programmable Codes
LaForge
Vehicle: Ford Focus 2011 - Frostwhite LaForge Edition
Post by LaForge » Wed Feb 15, 2017 4:47 pm
Hi Folks,
after playing a while with my modified ELM Adapter and the actual ForScan Beta release I have found the following Codes for Mustangs 2005-2009:
Its explained best with the BIN codes from the First 4 digit value
my original AsBuild Code was:
720-01-01 2083 0000 00CC and the first 4 HEX digits (2083) are BIN-values as follows: 00100000 10000011
you can see this 0 and 1 as little switches. so we take the secont BIN row:
First value: DRL LED OFF, if you need the DRL LED in your instrument Cluster you have to change the first 2 bits from 10 to 01. The second bit must be 1 then the green IC DRL Led flashes if you have DRL activated
Second calue: as above, must be 1 to use the DRL LED
third Value: The OpenDoor Symbol activation (if equipped in your cluster) if this is set to 1 (on V6 Base 4-Gauge models its set to 1) then the small red car with door open lits up if any door/trunk is open. (nice to have feature)
fourth value: Speed Limit Warning, a acoustig Warning if you drive above 85MPH (wo the FXck needs this????)
fifth value: Backup reminder, a chime sounds if you have entered the reverse gear (bing ... bing ... bing ...)
sixth value: TPMS on/off if set to 1 TPMS is activated, if set to 0 TPMS is not activated. (If you have no sensors)
The we take the 726-01-01 GEM
00000000 is the first BIN value row.
first value: DRL ON/OFF, if set to 1 DRL is activated (you need the IC Value above to activate LED in Cluster also (if equipped)
Hint: 2006 Cluster do not have all LEDs equipped. In my Cluster the DRL LED and the OPENDOOR LED were not fitted onto the Mainboard. So i bought an old V6 Cluster and ripped two LEDs off and plugged them onto my GT Mainboard, now all
places are filled and functional.
You can check if you have LED equipped with the IC Module self Test with ForScan.
This List will be modified if I know new features.
Greets :ugeek:
Karsten
the meaning of the BIN values in IC (HS CAN)
a fully equipped cluster in self test mode
riding da White Beast :lol:
ECU Programming Service on Ford Vehicles after 2006
Todd Ector
Vehicle: 2004 F150 XLT , 5.4 3v sohc 300hp
Re: Mustang S197 2005-2009 programmable Codes
Post by Todd Ector » Fri Mar 10, 2017 6:30 am
Thanks for sharing, the speed warning system is mandated by law for vehicles sold in the Gulf State regions, I could be wrong but I wouldn't be surprised if some of the car rental places use it too.
Actually I have it enabled on my 2004 F150 to help me with my lead foot problem... :-)
leandro34715
Vehicle: 2015 F-150 XLT V8 5.0 *** 2009 Mustang V6 4.0
Post by leandro34715 » Sat Jun 10, 2017 1:03 pm
Thank you for your good work. I have a set of rims with no tpms and the error messages just bothered me so much, I turned it off and its gone!
Please let us know if you find any other codes that could be programmed!!
Thank you again!
JetExpress_6.7
Vehicle: 2014 Ford F250 6.7L Powerstroke
Post by JetExpress_6.7 » Wed Sep 06, 2017 4:04 am
LaForge wrote:Hi Folks,
Greets :ugeek:
Karsten
Karsten/Laforge, that's some great work! Have you by chance figured out which line of coding will disable hyperflash or the "bulb outage warning" on the mustang? I am pretty familiar with the as built mods on my truck, but this BCM-B stuff on the mustang is throwing me off, completely different coding. I though maybe it would be close...
LaForge
Post by LaForge » Tue Nov 07, 2017 9:36 am
@jetexpress
Sorry, I have been away a long time.
Can you explain what you actually mean with hyper flash or bulb outage warning?
Does the 05-09 have such a feature?
Best regards
Karsten
JetExpress_6.7
Post by JetExpress_6.7 » Mon Dec 04, 2017 7:07 pm
LaForge wrote:@jetexpress
Best regards
Karsten
I apologize for just now responding Karsten, I haven't been getting email notifications for forum updates! I will make sure I do from now on.
The bulb outage warning is just that, when a turn signal burns out on a vehicle, the electrical system can detect an increase or decrease in "normal" resistance through the incandescent bulb. The BCM then signals to flash the turn signal about twice as fast as normal (dubbed hyper-flashing). Now, say you install an LED bulb (which draws MUCH less current/resistance) the car thinks the bulb has burned out and begins to hyper-flash.
All cars have this feature, and most of the later models now have a way to disable that. My F250 for example is a user selected option right in the Personality section of the programming. The mustang however isn't a simple plain english option, but I'd be willing to bet that it can be altered via the BCM as-built code.
LaForge
Post by LaForge » Tue Dec 05, 2017 7:26 am
This will be very funny.
So you can use LEDs instead of Bulbs.
My 2006 is regrettably locked so I can access only the first line of my Modules. (i.E. 726-01-01)
2007 and later has full access to all 20 Lines of the GEM.
Mustang Turn lights are controlled by the SJB (GEM)
There you may find this feature.
Keep us informed!
BR
Karsten
68gt500
Vehicle: 2008 Mustang Bullitt 4.6L 320 HP
Post by 68gt500 » Wed Jan 23, 2019 7:26 pm
Thank you!
I was finally able to switch off that stupid TPMS thing... :x
720-01-01:
original: 2007 0000 0050
New: 2003 0000 004C
I only changed 07 -> 03 Forscan inserted the correct ending 50 --> 4C
Very cool!
Car: 08 Mustang Bullitt
Greetings
Mike
6t07t
Vehicle: Mustang 2008
Post by 6t07t » Sun Feb 10, 2019 4:31 pm
I'm new here :D
Please help me with these problems:
- how to change radio frequency with 0.1 step (EU standard) on the 2008-09 factory satelite navi system??
- how to change US to EU road maps on the 2008-09 factory satelite navi system??
- how to disable bulb out hyperflashing with parking/turn lights LED bulbs?
please let me know,
thanks,
Peter
Juice
Post by Juice » Sun Feb 10, 2019 5:54 pm
Can't help with radio or navi, sorry.
I was unable to fix hyperflash with Forscan. I ended up installing resistors to get rid of hyperflash after installing LED bulbs.
