Navigation lockout while moving
tandw09
Vehicle: 2014 Ford Escape
Post by tandw09 » Tue Oct 18, 2016 5:53 pm
Hi. I know there has been some discussion in the past about being able to edit the Sync 2 Navigation while the vehicle is moving.
Is there an accepted procedure to disable the Navigation lockout while moving? Thanks.
Relak
Vehicle: 2017 GT350
Re: Navigation lockout while moving
Post by Relak » Mon Nov 07, 2016 7:09 pm
Still trying to figure this one out, myself! I hope someone figures it out soon!
redden
Vehicle: 2012 Ford Focus 3, 2.0 GDI/160 HP
Post by redden » Tue Nov 22, 2016 1:11 am
CombatDork
Vehicle: 2013 F150 FX4 3.5L EB - 2003 Explorer XLS 4.0L
Post by CombatDork » Fri Dec 22, 2017 6:59 pm
In a 2013 Explorer the APIM 7D0-02-01 block contains the data you would need to change.
Assuming that you're US, your data should be either 4153 or 5553. If you change that to read 5753 then you should have full navigation while moving.
I have not tried using 4753 yet but I want to see if that works as well.
XR6John
Vehicle: FGX XR6 ecolpi 2014
Post by XR6John » Tue Jan 22, 2019 5:05 am
Any help to disable lockout with sync2 for Australia?
lenko
Post by lenko » Mon Feb 11, 2019 12:03 am
In the new Forscan - APIM Module Configuration I have an: Ability to change address in motion - enabled or disabled.
Have a look there. There are also some other enable/disable settings there plus setting your country code.
