Ford Fiesta 1.4 TDCI Injector order problems
Gear
Vehicle: Ford Fiesta 1.4 TDCI 2009
Post by Gear » Sun Oct 02, 2016 6:33 pm
Hello. Thank you for accepting me in your group. recently I've got a big problem with my Ford Fiesta 1.4 TDCI 2009 car. the message on the display showed that there is problems with car's engine. scanner showed error P1203, which was 3rd injector. Official Ford Service replaced this injector. However, after 200km, the same error appeared on the screen. When I asked them to show me which injector they had replaced, they counted number 3 from the left to the right and circled injector 3. Now they insisting that they replaced the right injector, however, they contacted the head office of Ford in the UK, and with their assistance and firing order, they manually switched all injectors (placed them into different positions). they just contacted me and said (they were surprised), that computer shows fault of injector 2. they blaming computer and advised me to change an entire computer (PCM or ECU). I did a lot of research (and with the help of your blog), I think that they didn't replaced the fault injector, as well as they don't really know, where exactly this second injector is. i have program FORScan and awaiting for the cable. because my car is still in the ford service, could you please help me to figure out the correct location of injectors and how to figure out their physical location (I just wan to know, did they removed and replaced faulty one, or is this broken injector still "travels" from one cylinder to another).
could you please tell me which option is correct, if any.
pietr
Vehicle: Fiesta 2007, Fiesta 2013
Re: Ford Fiesta 1.4 TDCI Injector order problems
Post by pietr » Fri Oct 07, 2016 6:02 pm
P1203 means that there is a problem with the injector of cylinder 3. Hence the injector numbering and firing order don't matter for this code, only the cylinder numbering. As indicated on your picture, you need to start counting cylinders from the right side (gearbox side) on this engine. I'm 100% sure about this info because I just fixed my 1.4 TDCi Fiesta with code P1203 two weeks ago. I verified which cylinder the fault code was referring to by unplugging different injectors, starting the engine and then seeing which fault codes pop up.
Hope this info helps you.
Gear
Post by Gear » Sat Oct 08, 2016 10:33 am
Thanks a million for your post, pietr. You just clarified my doubts by 100%. I followed your instructions and it proved that you gave absolutely professional advise. Thanks again :)
