mondeo mk5 other features asbuilt
zjohnny
Vehicle: MONDEO MK5 TITANIUM 150CV DIESEL
Re: mondeo mk5 other features asbuilt
Post by zjohnny »
Another question, but can the Dashboard display the gear with the automatic gearbox you are traveling at?
rikbast
Vehicle: Ford Mondeo, 1.5 tdci 120 Pk, 2016
Post by rikbast »
What about activating intelligent speed control. Works by traffic sign recognition and the limiter function. Manually it works, but getting the auto speed control did not work. It is used on the S-Max, wonder I you could get it working on a Mondeo MK5
vacoh
Vehicle: mondeo, T7CF 2,0/110kw ,2015
Post by vacoh »
zjohnny wrote:
Sun Nov 10, 2019 11:43 am
Ok thx. Flash IPC with forscan is it impossible ?
but do I also need to replace the dashboard or do I just need to update the firmwire?
I would also like to have it in the middle. It is possible to only update SW now is in the right speed
zjohnny
Post by zjohnny »
Ok bro thank you so much
zjohnny
Post by zjohnny »
And have you news about Parking option with auto-brake ?
zjohnny
Post by zjohnny »
Is possible This changes in the video? https://youtu.be/1CkwT71RPVs
zjohnny wrote:
Sat Feb 29, 2020 5:40 pm
You have to flash newer firmware on your IPC
and later you can enabled digital speedometer in the IPC center
zjohnny
Post by zjohnny »
Have you a guide step by step for me please? Why to flash ipc for me it would be the first time thank you very much
zjohnny
Post by zjohnny »
I documented myself, correct me if I'm wrong, I can only update it with UCDS not with FORSCAN So I have to have a valid license of that program, all correct?
