mondeo mk5 other features asbuilt
AmigaSurfer
Vehicle: Mondeo MK5 1.6l Ecoboost
Re: mondeo mk5 other features asbuilt
Post by AmigaSurfer » Tue May 15, 2018 6:17 am
Do not change whole bytes, only single bits. If you change 0x01 (00000001) to 0x04 (00000100), you will clear the last bit and disable its function (LED Low Beam Fault).
For TPMS you have to set the 4th and 5th bit. Counting from left to right, beginning with zero.
So the right value for you is 0x0D (00001101).
Peter Gatland
Vehicle: Ford Mondeo Vignale 2.0 TDCI 210 PS
Post by Peter Gatland » Tue May 15, 2018 6:26 am
Thanks Amiga Surfer. So just to clarify you are saying the code should be: 0D03 0084 00B4
oslowek
Vehicle: fiesta mk7 2012 1,0 100KM / mondeo mk5 2015 150KM
Post by oslowek » Mon Jun 18, 2018 9:08 pm
Hi again,
I have bought F6 SD card and navigation was activated on my sony radio, already.
Used camera from other mondeo was bought and installed, too. Working almost very well. Almost because I see on my sony full rear view from original camera but I can`t see dynamic lines connecting with steering wheel movement. Only I see static lines (green, orange and red). Camera activated was only in APIM 7D0-01-01. I changed only second bit (xXxx xxxx xxxx) from 8 to A.
What should I change to active dynamic white lines, yet?
Best regards
Ondraszek
jeus
Vehicle: mondeo,2.0 tdi, 180cv, 2016
Re: mondeo mk5
Post by jeus » Sun Jul 08, 2018 7:44 pm
Hi . Very good Thanks I have a mondeo mk5 2016. 2.0 TDI. When I buy it the default lights are on as a drl. I can not deactivate or deactivate. He managed to launch the option to deactivate or deactivate from the scorecard. With the code 720-02-01 xxXx the value x I was A if you added 4 becomes É. And it appears. Then I also change 726-21-01 xxxx xxxx xXxx there is 1 enabled. 726-21-01 xxxx XXxx xxxx. There is 7f. 726-50-01 ay I got a little mess I put xXxx 4 the fog lights. Nothing does nothing, put the sea does nothing. I have run out of DRL. Help. Thank you
jeus
Re: mondeo mk5
Post by jeus » Sat Jul 14, 2018 7:10 am
Hi. It is already solved. In case someone has the same. my factory car to be km0. Brings the long light drl. default. and you can not ask or put. when activating this function. the drl only works when it is automatic and it is daytime. When I programmed it in the dark garage, it did not work. since the lights were switched on automatically. but to try of day. works correctly. Thank you.
silverwings
Vehicle: Mondeo Mk5
Post by silverwings » Wed Sep 19, 2018 5:53 am
Anyone know the codes to add the trailer sway control and tow bar electrics? Thanks
McAn
Vehicle: Mk5 Mondeo
Post by McAn » Fri Oct 26, 2018 8:35 pm
Anyone know if it's possible and how to change the way trip/fuel consumption shows? As for now it looks pretty basic like this:
And I want it to look like this:
AmigaSurfer
Post by AmigaSurfer » Sat Oct 27, 2018 6:15 am
You need someone with UCDS, who can upgrade the firmware of your IPC to at least GS7T-14C026-AJE.
See here.
Marek
Vehicle: Mondeo mk5, TDCI 2.0, 150KM, 2017
Post by Marek » Mon Oct 29, 2018 10:19 am
Hi
I have mondeo mk5 2017, how to change psi / kPa and bar, I only have psi / kPa, I would like to have a bar. Activate 720-04-01, xxXx xxxx xxxx 8 (Enabled).
