Errors in BECM config
Automate
Post by Automate » Sat Jun 04, 2016 4:26 am
Not a high priority since I don't need to change anything but I'm seeing errors on the BECM config screen (version 2.3.2)
BECM Config errors.PNG (168.75 KiB) Viewed 1747 times
Re: Errors in BECM config
Post by FORScan » Fri Jun 10, 2016 7:41 am
Ok, we will add numeric values in the edit dialog (similar to the one we made for Central configuration). It doesn't solve the problem, but will give more information for analysis. For example, the config battery age will look like the following:
So everyone can see the reason: value is not descrete and this is why error is displayed. This parameter has to be changed from list to numeric, and better in months than in years.
