Need to reprogram rear camera
Aymanodat
Vehicle: Ford mondeo 2016
Re: Need to reprogram rear camera
Post by Aymanodat »
No one know how to enable the guide white line ?
Aymanodat wrote:
Sun Jun 13, 2021 8:24 pm
What kind of camera, OEM camera, after-market camera.
What kind of display?
More information is required.
Aymanodat
Post by Aymanodat »
Ecmbuster wrote:
Mon Jun 14, 2021 12:13 am
I bought after market camera This one
https://www.amazon.co.uk/dp/B07GWLJGTL ... UTF8&psc=1
My car ford mondeo 2016 with sync 2
The camera work fine with red green and yellow fixed guidelines not white line
If you had SYNC in the car before, it should have the correct firmware.
If SYNC was installed after, that should have been mentioned first.
If the camera is after-market, follow their installation instructions and request their support first.
If the camera still fails, ask for a replacement or install OEM.
Aymanodat
Post by Aymanodat »
Ecmbuster wrote:
Mon Jun 14, 2021 3:57 pm
The car didn’t come with reverse camera i had to buy Harness Cable with rca to connect the camera and i enabled the reverse camera through forscan
aekkaphan
Vehicle: ford ranger2016
Post by aekkaphan »
I want to activate Reverse camera distance guide line Turn along the steering wheel (dynamic) in sync2.5 and sync3
please help me
wgraggio
Vehicle: lincoln mkz 2015
Post by wgraggio »
Same problem, interlink or calibration stop at 8% with new oem camera on lincoln mkz 2016, i changed my camera with the same part number.
i changed it because the older one got paint on the lens. With the new one, sometimes i see the guidelines, and most of the time, no.
I think there must be another procedure, before BCM calibration , reset or interlink .
Rolfecat
Vehicle: Ford Mustang, 2.3 Ecoboost, 2016
Post by Rolfecat »
Do you have the engine running?
wgraggio
Post by wgraggio »
No, FORSCAN says ignition ON but do not run engine. Why?
Rolfecat
Post by Rolfecat »
I’ve found that sometimes the engine needs to be running. Give it a try and you may find it will complete the process.
