Need to reprogram rear camera
DnBBullard
Vehicle: 2016 Ford F550 6.7 diesel
Re: Need to reprogram rear camera
Post by DnBBullard »
tuscoops wrote:
Sun May 24, 2020 9:22 pm
Hi Admin,
Is it possible to have you run this procedure for myself also? More than happy to provide feedback and results etc.
Thanks!
FORScan wrote:
Sat Apr 30, 2016 3:30 am
braxx is right, a special procedure is required to initialize the camera. It is not available in FORScan yet, but we are ready to implement it for you if you can test it with your vehicle. Please see PM for details.
I also need to run this procedure, can I get the code?
jpgray27
Vehicle: F150 Limited, 3.5L V6 EcoBoost, 2013
Post by jpgray27 »
DnBBullard wrote:
Sun May 24, 2020 9:40 pm
Hi Admin,
Thanks!
I too am needing to run this procedure for my rear camera. Would you be willing to send it to me?
Thank you!
RichieFly
Vehicle: Ranger, TD3200, 2016
Post by RichieFly »
Hi.
Any updates to this?
Thanks.
This function was added several years ago. There are 2 types of functions:
1. Rear camera calibration
2. Local Interconnect Network New Module Calibration
Both are used for rear view camera calibration. The functions are available for BdyCM and/or IPMB module.
If such a function is missing for your car and you believe it must be available for your car, please contact support and provide your car details (model , year).
kevtough
Vehicle: Ford Focus ST 20l Turbo 250 bhp 2016
Post by kevtough »
My sync3 has these setting but there are no active guidelines.
jpgray27
Post by jpgray27 »
FORScan wrote:
Mon Jun 15, 2020 1:50 am
If I see the general BdyCM test but not specifically the BdyCM (rear camera) test, would the general BdyCM still work on the camera?
stephenfranco714
Vehicle: Flex, V6, 2014
Post by stephenfranco714 »
I have the same issue/question as jpgray27. Not seeing a specific BdyCM rear camera test listed as others have mentioned running.
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Post by mschumiv »
My vehicle is a little different: no APIM module and no FDIM module (Ford Focus MK4 2019 - Europe), all the camera related processes are run only on BCM and ACM module.
I have the same problem, no camera guide lines and no zoom control. This happened after a SYNC system (light) (in my case stored on ACM module) update done at the the dealership, 6 months ago. They couldn't fix this yet!!! (maybe don't want to or don't know how)
I have the same DTC B115E:55.
Running Local Interconnect Network New Module Calibration, stops at 8%, no fix.
I'm thinking of visiting Ford factory in Germany, maybe they know how to fix this... it's like a 2000km trip!!!
Barakeko
Vehicle: Ecosport, 1.0 Ecoboost/125, 2019
Post by Barakeko »
mschumiv wrote:
Mon Jun 29, 2020 6:01 pm
Did you find any solution for this as i have the same problem and also my car doesn't have APIM module.
also which configuration i've to change in BCM module for the camera?
mschumiv
Post by mschumiv »
Barakeko wrote:
Tue Jul 14, 2020 2:09 pm
No solution yet...
What do you want to change for the camera?
