Need to reprogram rear camera
SventeHof
Vehicle: Ford Focus Titanum 1.0 125PS
Re: Need to reprogram rear camera
Post by SventeHof » Wed Apr 05, 2017 8:23 pm
Hi to everybody,
i have the same Problem :-( No white Lines, no zoom..
My Car: Ford Focus 1.0 Titanium 2015 with sync2
I bought original Camera, cable and braket, connect the camera (Video +, Video -) -> Sync2 Module and the LIN -> BCM Module.
I cahnge vie Focccus the BCM #99 Park assist Camera to "02 With Park Assist Camera" and via forescan the sync2 asbuild data 7d0-01-01 fom 09 to 0B.
When i put the car in reverse gear, the camera is shown on the touchscreen and i see the green/yellow/red lines, and the magnifier.
There are no white lines also if i move the steering wheel. If i push the magnifier, there also didn´t change the sreen.
I dond´t know what to do.. Must i initializied the Camera?
Sven
D-K
Vehicle: Ford Focus MK3, 1.0 ecoboost 100PS, 2014
Post by D-K » Thu Apr 06, 2017 2:06 pm
To activate dynamic guidelines and zoom feature, AS BUILT of BCM needs to be changed!
Go into "BCMii Module configuration (AS BUILT format)"
change 726-01-06 from 1240 to 9240
Two of my friends confirmed that this change worked on a Ford Focus :)
Keep the trunk closed! Otherwise you don't see the guidelines.
For other models, this could still work. However, if the data is different then try to increase by 8 hex
e.g. if 726-01-06 is 5240, change it to D240
But please do this at your own risk. You can restore the original back in case of problems.
andresmorago
Vehicle: 2015 Focus SE
Post by andresmorago » Tue Jun 20, 2017 3:02 pm
Hello to all
i would like to consult if theres any way to reprogram my camera on a 2015 Focus SE. I just installed a SYNC2 APIM and im having the following issues:
*Video is OK
*Parking lines wont move according to steering wheel
*Parking aids (color blocks) wont show at all
Im running version 2.3.8 beta with extended license. i dont see the reprogramming camera function when i connect to forscan and believe this will help me fix these issues,
Or...is the "Local Interconnect Network New Module Calibration" the one i need?
Thanks so much
andresmorago
Post by andresmorago » Tue Jun 20, 2017 11:53 pm
Hello again
I was able to enable the parking aids by modifying the APIM ab data:
7D0-01-01  2A21  9001 E2EF
Now i get a small car drawing on the right top area of the screen with the 4 parking sensors. :mrgreen:
Im still struggling on the parking active lines. After modifying the byte shown above, they momentaniosuly show for 1 or 2 seconds (they even move with the steering wheel) the very first time i boot the sync apim but they just go to the center of the screen after that and dissapear! :?:
this is my ab data so far
7D0-01-01 2A20 8402 20C9
7D0-01-02 0408 5300 023B
7D0-02-01 5552 0001 0082
7D0-02-02 0200 0000 00DD
7D0-02-03 0000 DC
7D0-03-01 1F4D 4601 008E
7D0-04-01 0103 0201 00E3
7D0-04-02 0001 DE
Myrdin
Vehicle: Ford Ranger Limited 2016
Post by Myrdin » Sat Jun 24, 2017 5:54 pm
Hello!
I need some help for reprogramming my rearview camera in my Ford Ranger 2016.
I have no active white Lines :-( only yellow, green and red will showing.
Please help me!
Thanks!!!!
explorer2012
Vehicle: Explorer LMT, V6 3.5L, 2012
Post by explorer2012 » Tue Jun 27, 2017 4:47 pm
FORScan wrote:braxx is right, a special procedure is required to initialize the camera. It is not available in FORScan yet, but we are ready to implement it for you if you can test it with your vehicle. Please see PM for details.
Can you provide me with the special procedure required to initialize the camera?
thanks!
andresmorago
Post by andresmorago » Fri Jun 30, 2017 3:00 am
I was able to represent my issue with the parking lines. I can see them working only for 5 seconds and just right after rebooting the apim. After that, active lines will disappear
https://youtu.be/qbMgNHXNsT8
Edit:
I ended up fixing this damn issue by performing a master reset from the apim menu. That simple it was :roll:
A forscan module reset couldn't fix the issue.
eido
Vehicle: Ford Everest 2.2L 4x2 AT 2017
Post by eido » Tue Sep 12, 2017 9:04 am
is there a way to make this work on Sync 3? i added a reverse camera but it is not a ford oem reverse camera
the-drew
Vehicle: 2017 f150 2014 transit connect 2012 transit conn
Post by the-drew » Tue Sep 12, 2017 7:23 pm
I have a 2017 f250 I installed the factory camera with the 4" screen but cannot figure out how to get the lines or the zoom to program any help would be greatly appreciated!
eido
Post by eido » Wed Sep 13, 2017 5:02 am
how do you perform a master reset of the apim?
