DPF adaptations reset at S-Max/Galaxy 2.0 TDCI 103kw
erikfrog
Vehicle: Civic VII 1.4 66kW 2003
Post by erikfrog » Thu Aug 07, 2014 8:17 pm
Hallo, i can´t find service function to reset DPF adaptations which is needed when DPF filter is replaced. When fault P2463 present.
Many thanks
Re: DPF adaptations reset at S-Max/Galaxy 2.0 TDCI 103kw
Post by FORScan » Fri Aug 08, 2014 10:27 am
erikfrog wrote:Hallo, i can´t find service function to reset DPF adaptations which is needed when DPF filter is replaced. When fault P2463 present.
Many thanks
2.1.18 has no this functionality (implemented only for Mondeo Mk4 Stage V), it is implemented in 2.1.19 (link to test version is sent in private message)
erikfrog
Post by erikfrog » Fri Aug 08, 2014 3:10 pm
Thanks, i will test. :)
wozio
Vehicle: Mazda 3 BK 1,6 MZ-CD
Post by wozio » Sun Aug 10, 2014 3:28 pm
I want that too! :) If it has mazda 3 bk y6 service functions implemented. :) I can't wait eny longer for beta version to download :)
Post by FORScan » Mon Aug 18, 2014 12:56 pm
Beta was re leased on 11th Aug :)
lucano99
Vehicle: Ford Focus 2.0.TDCi
Post by lucano99 » Thu Aug 21, 2014 7:26 am
Hello.
is it somehow possible to reset the system, when the DPF filter has been replaced? We are going to do it this weekend.
Is there any software.. or any howto, howto do it?
thank you :)
Lukas
Post by FORScan » Fri Aug 22, 2014 9:43 am
Depending on the model, there should be DPF and DPS (differential pressure sensor) learned values/adaptations reset functions in FORScan. We also recommend to find and follow a workshop manual for your model as the DPF replacement service is different for different models and may have some specific (mentioned in the manual).
Also, it should be counted that functions are different for different models, and some implementations are yet missed in FORScan. So it is recommended to check in advance.
erikfrog
Post by erikfrog » Sun Oct 12, 2014 8:19 pm
Tested and works. Many thanks.
