Delete dtc codes with forscan lite
hoopsbhoy
Vehicle: Focus Ghia 2l 2007
Post by hoopsbhoy »
Hi can anyone help please
Is it possible to delete codes with he forscan lite app, I know I can do this using Windows but just wondered if this can be done using the forscan lite app, the reason I'm asking is that I had a problem with my immobiliser coming on and was stranded miles away from home and no access to the laptop, I had to get a garage to delete the codes and turn off the Elm before I could get it started amd now worried to drive the car in case it happens again, so thought if I can use the lite app to delete or reset the codes as I always have my phone and the adapter at hand, thank you in advance
Don Ridley
Vehicle: 2016 Transit Connect
Re: Delete dtc codes with forscan lite
Post by Don Ridley »
Yes, Forscan Lite can clear/reset DTCs. I leave my OBDLink MX plugged in all the time and frequently check PIDs and DTCs with Forscan Lite.
hoopsbhoy
Post by hoopsbhoy »
Thank you Don, will install the app much appreciated.
