lincense key
james6811
Vehicle: f150,2,7 eco.2018
lincense key
Post by james6811 »
i cant seem to get my key is there another way to add it? i have downloaded it many times and it wont go in..
Re: lincense key
Copy your license key to the Forscan folder
C:\Program Files (x86) Forscan
Go to FORScan and load the file from that folder.
james6811
Re: lincense key
Post by james6811 »
thats what ive trying to do but i cant figure out what i am doing wrong.
Re: lincense key
Post by tractmec »
james6811 wrote:
Sun Jun 13, 2021 5:39 pm
Check your computers date and make sure it is current.
Do not PM me as I am not an Admin nor am I a member of the FORScan Team and all questions should be asked and answered on the Open Forum so all can benefit!
Re: lincense key
Try this "how to".
License how to.pdf
(493.48 KiB) Downloaded 44 times
james6811
Re: lincense key
Post by james6811 »
Finally got it. Had to generate a new key and it went as planned. Thanks. Well go and make some changes in the morning.
LEWIS23
Vehicle: Ford mondeo 2.0tdi 140bhp 2008
Re: lincense key
Post by LEWIS23 »
IM HAVING THE SAME PROMBLE IT COMES UP LIKE THIS CAN ANYONE HELP REGEDIT4
[HKEY_CURRENT_USER\Software\Astech\FORScan]
"Key"="2mhk5pmAVj8/gU2jE/Q7JcBOa07JTe+/UfIaUcAIgA49aaqEoPa45OsENo/hGE1eHvXEti7hSZfHKdUV8hcJcmzxbJXIJbiPDPj4n3x00U1NC7eW0EloP0blDokEFXkvRGmBJjcgQJFIFTZAkum0/HqyhdG1yQOcNYuoFas9x6Z8="
"Id"="7B691BCE-4EE7"
"KeyV2src"="0F0000000000000002000000000000004742414139342D4A565439522D4552324D392D544D4546532D45373552372D59523352442D4A324B59502D5A3543474B2D51473248442D4A4E3632392D4B3255464A2D59553533340D53746576656E20577269676874000000000000000000000000000000000000000000000000FFFFFFFF"
"KeyV2"=hex:0f,00,00,00,00,00,00,00,02,00,00,00,00,00,00,00,47,42,41,41,39,34,2d,4a,56,54,39,52,2d,45,52,32,4d,39,2d,54,4d,45,46,53,2d,45,37,35,52,37,2d,59,52,33,52,44,2d,4a,32,4b,59,50,2d,5a,35,43,47,4b,2d,51,47,32,48,44,2d,4a,4e,36,32,39,2d,4b,32,55,46,4a,2d,59,55,35,33,34,0d,53,74,65,76,65,6e,20,57,72,69,67,68,74,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,ff,ff,ff,ff
Re: lincense key
Another one that types in capital letters. It is considered as YELLING!
Here is your key decrypted but you should read the entire post and other posts with the same repeating problem.
GBAA94-JVT9R-ER2M9-TMEFS-E75R7-YR3RD-J2KYP-Z5CGK-QG2HD-JN629-K2UFJ-YU534
Steven Wrightÿÿÿÿ
The registry means nothing!
Completely remove FORScan and reboot.
Use a registry cleaner and reboot again. **CCleaner works fine, Little Registry Cleaner is as good**.
Install FORScan and go back to the page and download the CORRECT license for the CORRECT hardware number attached to that laptop.
Cut and paste that key from the download folder to C:\Program Files (x86 )\Forscan
Open FORScan "Load License Key" and access that specific key inside the FORScan folder and click "OK". FORScan will restart.
Post your results.
