battery learned value reset 2014 Mazda 3 Skyactiv D
jakbla
Vehicle: 2014 Mazda 3, 2.2 Skyactiv D
Post by jakbla »
Recently my battery died for good so I replaced it.
Now I heard that new battery needs to be "programmed", which I think is simply resetting learned values. I was looking everywhere, but couldn't find that procedure. Is it me or that procedure is not available for that model? If it is where I can find it?
Thank you in advance.
Re: battery learned value reset 2014 Mazda 3 Skyactiv D
2014 Mazda 3 2.2L Skyactiv D
Use this tool for image capturing.
Send the shortcut to the desktop and taskbar.
Snipping Tool
Snipping Tool
Snipping Tool.JPG (63.81 KiB) Viewed 305 times
It would be interesting where you may have heard that comment.
If you have FORScan, post the entire network scan with the installed controllers (Modules) list.
Modules
Modules
Mazda Modules.JPG (102.7 KiB) Viewed 305 times
Click the "Wrench" icon
Post and image of the options at the "Service Procedures" screen.
miz
Vehicle: Mazda CX-5
Post by miz »
1. Switch to ON
2. Shift level to N position
3. Depress brake pedal and hold until the end
4. Depress acc pedal for >5 sec
5. Check if battery warning lamp started to blink
6. Depress and release acc pedal 3 times
7. Check for no warning lights.
BATT_DAY will became 0 days.
jakbla
Post by jakbla »
miz wrote:
Sat Jun 12, 2021 12:02 am
1. Switch to ON
That worked perfectly, battery is reset now. Thanks.
Ecmbuster I will try to attach screenshots later, maybe you will be able to locate this function. For future reference.
