Transit Custom 2.2 125PS Injector Pilot Learn
toys4x4boys
Vehicle: Transit Custom 2.2 125PS 2014
Post by toys4x4boys »
2014
Recently fitted 4 new injectors.
Did an injector pilot adaptations reset.
Then went on to do a pilot learn.
Seems to start off fine, revs the motor to 4000 rpm and back to 1500 rpm
Eventually shows 100% on progress bar, then drops back to 50% and goes through the cycle again.
I let it go through 4 times, took just under an hour, but it then carried on.
i eventually had to turn the van off.
How long should it take ?
Is the above normal ?
Should I see some other form of progress marker ?
Cheers
Graeme
Re: Transit Custom 2.2 125PS Injector Pilot Learn
2014 or 2015? Your post and user configuration do not match.
Post screen images with the Module networks connected and all faults.
Take images of the old injectors and note the type.
Take images of the new injectors and note the type.
Post all the images.
At idle, what is the specified FRP and actual FRP.
FRP. psi
FRP_DSD, psi
Post that image as well.
Did anyone at least enter the calibration from each new injector?
Were the calibrations entered into the correct cylinder?
toys4x4boys
Old Injectors Marked Ford
New Injectors Siemens VDO
Coded into correct spot.
Even took the pictures to compare before coding comit.
Will get other pictures next
toys4x4boys
More screen captures
Use this tool to capture clear images off the laptop using this example. Send a shortcut to the desktop and taskbar.
Snipping tool
Snipping tool
Snipping Tool.JPG (63.81 KiB) Viewed 267 times
Fuel Rail Values
The idle pressure should be close to 240 bar
The cranking pressure should be close to 320 bar
Your values are very close
FRP 22420.0 kPa = 224.2 bar
FRPD 22000.0 kPa= 220.0 bar
On some and not all models, the mechanical or electronic parking brake needs to be set before adaptations.
Make sure there are no faults recorded.
FORScan should have the option to clear all learned values. Perform that task.
Exit FORScan and cycle the ignition OFF to ON and enter FORScan again.
The engine should be at operating temperature before performing this task.
If you have the correct software / firmware in the PCM, the procedure can take 45 minutes or longer for the injector pilot adaptation relearn.
The best advice is to access Ford etis for the current instructions but be aware you need to follow IDS instructions but they should match FORScan.
If you accessed Ford etis with your VIN, save a copy of your specific instructions and post them to match.
toys4x4boys
THanks
Did a clear all adaptations.
Then a pilot learn again, took just over an hour to complete.
Much better sounding engine now.
Cheers
