AGM battery configuration
RugbyAl
Vehicle: Mondeo Vignale 2.0 bi turbo 2017
Post by RugbyAl »
Hi. Just replaced my EFB battery after it failed (Covid lack of use, short journeys) - 3 years old. Decided to replace with AGM, and I was informed by vendor that Varta 096AGM was compatible.
I can find option to change battery type, but only 3 AGM options,
0 AGM 80AH 700CCA T7
1AGM 70AH 600CCA H6
2 AGM 80AH 700CCA H7
All other options appear to be EFB
The Varta 096AGM is 70AH 760 CCA. I have set to type 1, 70AH 600CCA and stop start etc working fine.
Does anyone know how to tweak to the exact spec of the 096AGM, or is that not an option / required?
Thanks.
lenko
Re: AGM battery configuration
Post by lenko »
Set it to BCM 726-04-01 01xx xxxx xxxx This for a AGM 760 70AH 760CCA.
RugbyAl
Post by RugbyAl »
Hi Lenko
Thanks for your reply. I set the battery type to 1AGM 70AH 600CCA H6 in the options given in the BMS, and I checked 726-04-01 and it is set to 01xx xxxx xxxx. Guessing the setting is closest possible option rather than specific settings?
Regards
Alan
lenko
Post by lenko »
https://drive.google.com/file/d/1EJnizs ... o6nS3/view
According to this you are probably ok as 01 seems to fit the 760 CCA.
RugbyAl
Post by RugbyAl »
Thanks Lenko, where is the source for that list please?
lenko
Post by lenko »
RugbyAl wrote:
Sun Jun 13, 2021 12:11 am
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
RugbyAl
Post by RugbyAl »
Excellent - thanks!
