Question about DPF Values Ford Kuga Mk1 2.0tdci 163
stef_90
Vehicle: Ford Kuga Mk1 2.0 163 tdci 4x4
Post by stef_90 »
Hello, does anyone know if these values are normal? There are no fault codes for DPF, and the car is running normally. Do I have to be concerned about the 300% Value of " DPF_SOOT_LD and the negative differential pressure - DP_DPF being -4 kPa ? And if yes, why is the DPF_LOAD 0%? Thanks in advance, and sorry about my bad English.
Re: Question about DPF Values Ford Kuga Mk1 2.0tdci 163
Use google to search your terms "DPF Values Ford Kuga Mk1 2.0 tdci"
Then read this:
https://www.fordownersclub.com/forums/t ... g-forscan/
stef_90
Post by stef_90 »
Hello again, it turns out that the car's software have been remapped, and the dpf was switched off in the software. That's why it shows abnormal values. I didn't know that the owner before me have done this procedure.
Interesting that you found that anomaly with the Ford.
That would also mean some hardware was replaced. Louder than normal exhaust frequency?
