ACM write error v2.4 Beta
CommaL
Vehicle: Ford Fiesta 2018 1.5 Dizel
Post by CommaL » Sun Jun 28, 2020 6:20 pm
I can't write ACM post-processing information
I replaced the ACM module
Re: ACM write error v2.4 Beta
Post by FORScan » Wed Jul 01, 2020 7:01 am
Are new and old ACM different? If yes, what configuration did you upload to the new ACM? If new ACM is different and configuration is from old ACM, it may simply not fit to the new ACM.
Also couple of notes:
1. Your 2.4.0 test build is very outdated.
2. It is recommended to use regular 2.3 version to manage configuration, last one at this moment is 2.3.33, we recommend use it.
CommaL
Post by CommaL » Wed Jul 01, 2020 7:09 am
yes new ACM ford fiesta mk8
let me try the latest software
roylion15
Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Post by roylion15 » Wed Jul 01, 2020 8:20 am
Hello
Why do you want to flash your radio ( ACM )?
There are a lot of different ACM models and if it’s not the same, you’ll have trouble putting back the Asbuilt data that isn’t intended for that one.
You will get DTC errors if the configuration is incorrect
No support in PM without invitation, please !
CommaL
Post by CommaL » Fri Jul 03, 2020 2:22 am
turkey simple multimedia 4 inches
sync3 APIM ACM and LCD screen changed but new module is in DSP support and I don't have DSP module
Looking for the new ACM DSP module
roylion15
Post by roylion15 » Fri Jul 03, 2020 7:33 am
Hello
What's the part number of the new ACM ?
can you post the Asbuilt data of the new ACM in attachement ?
and what you want to reflash ?
CommaL
Post by CommaL » Sat Jul 04, 2020 5:07 am
new ACM part number:H1BT-18C815-HP, target:H1BT-14V044, calibration:H1BT-14C45-ME
