4th Key no PATs options except initialize
Gurusi
Vehicle: Ford Ranger 2.3l 2007
Post by Gurusi » Sat Mar 07, 2020 1:16 am
Hey, first post. Just to confirm I have searched the forum/web for info before posting.
I have a 2007 Ford Ranger. Forscan v2.3.29 beta with an extended license. Keys were checked with B1601 as the DTC.
I had X1 original key and bought X3 extras (Strattec oem). I erased all record (2) and reprogrammed X2 new keys successfully.
I then went to ignition key programming for the 3rd key successfully. However the 4th and final key came up with an error on three occasions.
So i disconnected and tried again only to find that all of the PATs options were gone with the exception of Module Initialization, help and exit.
Module initialization completes successfully; however the same options remain.
My X3 keys are all good, the forth key is just nagging me!
I am i missing something obvious? can anyone help?
Gurusi
Re: 4th Key no PATs options except initialize
Post by Gurusi » Sun Mar 22, 2020 2:57 pm
Anyone?
Andyfocus
Post by Andyfocus » Sun Mar 22, 2020 8:44 pm
check and make sure that the option is set for more than x amount of programmable keys is checked.
Gurusi
Post by Gurusi » Mon Mar 23, 2020 9:39 pm
Hey, thanks for the info. I can not see any checkbox/option to specify the amount of keys within the GUI of the program. Could you tell me where it would be at? Or could it be a car model/year specific option?
Andyfocus
Post by Andyfocus » Mon Mar 23, 2020 11:03 pm
check out this page for more info on max keys and types etc.
https://www.motorcraftservice.com/pdf/pats_job_aid.pdf
also check out programming section in the forum maybe more info in thier in finding and checking the location.
Gurusi
Post by Gurusi » Thu Mar 26, 2020 8:30 pm
Thanks for the info. i did confirm the max number of keys as X8. after disconnecting the battery for a while and reconnecting I am now presented with a code that i believe is the issue:-
B2141-60 Non-Volatile Memory (NVM) configuration failure — No PCM ID stored in PATS.
I have no idea how this occurred or what the solution is. A web search gave me very little to work with.
If i clear the code it does not reappear; however i do get a B1352 when trying initialize PAT's (with an original key)
