No start on 2013 f150 5.0 2wd
taylorray1986
Vehicle: Ford F-150 5.0 2wd 2013
Post by taylorray1986 » Sat Oct 12, 2019 8:27 pm
I have a crank, no start issue on my 2013 2wd f150 5.0 it's not the #27 fuse. I bought the truck used with major impact damages on the passenger side. I did the body work, worked fine, untill......it rained. Had it few weeks then after a heavy rain it wouldn't start for about 2 days. Then it fired right up. I hoped it was a fluke but then few days ago took it to the car wash and when I went to start it and leave, same issue. Cranks all day bit wont start. I've checked grounds, connections, loose wires etc all to no avail. Showing codes the fcim lost.comm with the ipc, rcm says circuit open, bodycam circuit open or short to ground, ipc says lost command with bodycam, and hvac also says lost command with bdycm. I ran down so many wires and getting nowhere. Can somebody please point me in the right direction. I need my truck for work and I'm having absolutely no luck. Thank you
