C0089 on brand new F150
newstx
Vehicle: 2019 F150 STX SCREW 4X2, 2.7eco
Post by newstx » Thu Sep 12, 2019 12:46 pm
Hi I just used Forscan to check my brand new 2019 F150. It shows a DTC in ABS after initial scan (I haven't change anything yet) as follows. Can anybody tell what it is? Should I take my truck back to dealer for further diagnosing?
I am also confused by it says "Previously Set DTC - Not Present at Time of Request". Does it mean it is just a old code maybe left in factory test and right now there is no problem?
I am fairly new to Forscan and really appreciate for any education...
denbo
Vehicle: ford focus 16 zetec
Re: C0089 on brand new F150
Post by denbo » Thu Sep 12, 2019 6:01 pm
I wouldn,t worry about it. Just tell the dealer, its probably better to let them delete the old code. That way they have the evidence in case of future problems
newstx
Post by newstx » Fri Sep 13, 2019 5:56 pm
Thanks the reply. I deleted the code using forscan and haven't see it come back so far. Should be ok.
denbo
Post by denbo » Fri Sep 13, 2019 6:42 pm
OK but you have now lost the evidence. You might get problems in the future, and if it don,t throw a code your stuck. I think you are very brave messing with a brand new vehicle, still under warranty.
