Clearing P0546 error - a related question
Roybridge
Vehicle: Ford B-Max, Diesel 1.6, 2015
Post by Roybridge » Thu Aug 22, 2019 7:52 am
I have a P0546 (Exhaust Fas Temperature Sensor Circuit High) error in the PCM and OBDII modules of my Ford B-Max. I have run some Redex diesel particulate filter cleaner through the system, and I have cleared the code using FORScan. I notice that in the service menu, there is an option to reset the stored Exhaust Gas Temperature value. Should I be running that after clearing the fault code?
denbo
Vehicle: ford focus 16 zetec
Re: Clearing P0546 error - a related question
Post by denbo » Thu Aug 22, 2019 6:27 pm
If the fault has gone and not returned, leave it at that.
Roybridge
Post by Roybridge » Fri Aug 23, 2019 2:35 pm
Unfortunately, the code comes back a couple of days after clearing :(
denbo
Post by denbo » Fri Aug 23, 2019 6:18 pm
Looks like a new sensor required
