F150 U0131 Lost communications with power steering control module
badf150
Vehicle: F150 v8 20011
Post by badf150 » Wed Aug 21, 2019 1:23 am
All,
I have an F150 and the EPS has failed. I've run FORSCan and DTS indicates U0131 "Lost communications with power steering control module A".
I'm trying to pull the AS BUILT DATA for this module but it PSCM is not populated in the module list! Check out attached screenshot.
denbo
Vehicle: ford focus 16 zetec
Re: F150 U0131 Lost communications with power steering control module
Post by denbo » Wed Aug 21, 2019 8:26 am
Cant see how that would work.If you have no comms you cannot move forward.
jdmcl1
Vehicle: 2006 ford f150 5.4l
Post by jdmcl1 » Thu Aug 22, 2019 12:41 pm
Use this link, enter your vin and you will get the as bulit data for the truck. You have a communication problem with the pscm, either a bad module or a brake in the can buss. Make shure you check the fuses first.
