Ford Focus 1.6 2008, ABS B2477-E0
esetman
Vehicle: Ford, Focus
Post by esetman » Tue Aug 20, 2019 10:11 am
will you advise me what to do with this error?
carmelo
Vehicle: ford focus cabriolet 2.0 dtci 136cv
Re: Ford Focus 1.6 2008, ABS B2477-E0
Post by carmelo » Thu Sep 19, 2019 6:11 am
hello I had the same problem would you have the solution
esetman
Post by esetman » Fri Sep 27, 2019 5:55 pm
Hi, run the "ELMConfig" program.
Set the cable communication to HS-CAN
Select "ABS".
Connect to the Internet.
Fill in VIN
Click on "Load from As-Built". Then I checked "Emergency Brake Lights ...
Then "Write to ABS"
This helped me.
