Ford Fusion 2014 radio conversion to EU Frequency
kamis1822
Vehicle: Ford Fusion
Post by kamis1822 » Mon Aug 19, 2019 7:45 pm
I need help with my Ford Fusion ill try to set radio from USA to EU but i had an issue, i find solution in forscan forum but its not work :(
"You need to change the As built Data for the ACM:
727-04-01 x*xx xxxx xxxx
Change “*” for Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
Top"
but in my car i can find only something like this?
maybe someone could help me ?:)
shadovwv
Vehicle: Fusion US, 2.5L, 2016
Re: Ford Fusion 2014 radio conversion to EU Frequency
Post by shadovwv » Tue Aug 20, 2019 9:01 am
Hi, I think you go to wrong module. you're in APIM not ACM 7D0-04-01 are in APIM and 727-04-01 are on ACM
kamis1822
Post by kamis1822 » Tue Aug 20, 2019 11:27 am
Hi, thanks for tip, i'll check it in the evening :)
shadovwv
Post by shadovwv » Tue Aug 20, 2019 7:49 pm
ok check and tell if you make it ( ja sam ten błąd popełniłem ale dalej nie mam parzystych częstotliwości pozdrawiam).
kamis1822
Post by kamis1822 » Wed Aug 21, 2019 5:59 am
Hi shadovwv everything is ok made it :) (napisz pw powiem co zrobilem :))
