Where is the PATS menu? 2017 Escape
MR_Huns
Vehicle: 2018 escape
Post by MR_Huns » Fri Aug 09, 2019 3:10 pm
I am looking to do a parameter reset using the FORScan. I programmed the replacemt PCM. Now I need t odo a parameter reset so the PATS will work. I am trying to use your product as an alternative. I generated a free license. If it works, I will gladly buy a full lifetime license. Where is the menu options?
TimFor
Re: Where is the PATS menu? 2017 Escape
Post by TimFor » Tue Aug 20, 2019 12:35 pm
Read https://forscan.org/download.html to see if supported. Not by "Escape" but by "PATS" and then Escape. It's not.
MR_Huns
Post by MR_Huns » Sun Nov 10, 2019 6:55 am
Thank you.
