No ELM Found Error
wildcat22
Vehicle: Fusion, 2.0L, 2016
No ELM Found Error
Post by wildcat22 » Tue Jul 23, 2019 3:17 am
I have a 2016 Fusion and I am running FORScan on my Mac through CrossOver, which appears to be working well. When I connect my USB connection to the OBD port, I get a "No ELM Found" error. I've played around with the settings, disconnected and reconnected the connector, changed from HS to MS and back trying to get it to work. I don't know if its my connector, laptop, driver or something else. Any suggestions?
Here is the connector I have:
https://www.amazon.com/OHP-ELMconfig-Ad ... 165&sr=8-3
Here is the driver I downloaded:
http://www.totalcardiagnostics.com/supp ... d-software
Thanks in advance
duck hinter
Vehicle: 2003 f150 4.6 4x4
Re: No ELM Found Error
Post by duck hinter » Tue Jul 23, 2019 11:31 pm
I have had this same problem on my windows 10 with my ELMconfig
ALAN2121
Vehicle: Ford F150 2003 5.4l
Post by ALAN2121 » Thu Aug 01, 2019 3:18 pm
Did you fix the problem with the No ELM Found if so what did you do to fix it i'm running in to the same problem
wildcat22
Post by wildcat22 » Sat Aug 03, 2019 7:03 pm
I have not. I’m going to try using a PC instead of a Mac and see if that will work since FORScan is meant for PC’s.
