*.ABT format in FORScan
hayduke
Vehicle: 2018 Ford Transit 3.5L EcoBoost
Re: *.ABT format in FORScan
Post by hayduke »
I had posted my .CCT for my BSM on another forum
https://www.fordtransitusaforum.com/thr ... st-1049199
Here is one I saved from a 2018 Ford Transit. I can provide the ABT file or VIN as well if that's helpful.
Code: Select all
;Block 1
FE00318273713030350D0A3146545952325847364A4B4131393434310D0A0000000000000000000D0A0000000D0A0000000000000D0A00000D0A0000000000000D0A00000000000000000000000000000000000000000D0A
;Block 2
00000000000000000000000000000000000000000000000000000000000000000000000000000000
;Block 3
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
;Block 4
FC6F
;Block 5
650901002A01030149020901010100020001000101010101000101000204000201020202010001010002070101000100000057000001000103010101000900010100010E104645010401080100020130010001000101000102000000110000010101040005010001000100000302000A00000100000100000000020101000102000003000002000201020201020001040101040202000000000100000100010000000000000000000002000100000000010100010000000001010100000101010002000200010100000000000000000000010100000100010002030000010001010000000000050000000100000001010000010100000000000030440000
Ere
Vehicle: Ford explorer 3.5cc 2011
Post by Ere »
Can you help me with a link to a video tutorial where I can format .ab file extension to . abt extension? I have been trying to reprogram an apim I got from a ford edge to my 2011 ford explorer limited. The as built data I downloaded is in.ab extension and aren't loading on forscan. I'm stuck.
smartguy69
Post by smartguy69 »
Ere wrote:
Sun Jan 31, 2021 5:47 pm
I am not 100% but have you tried just changing the as built file name from .ab to .abt
I am sure I did that to load the apim details from a sync 2 car which I downloaded from the motorcraft site when I upgraded from sync 1 to sync 2.
Alternatively try this. You will be able to import the as built ab file and I am pretty sure you can save it as an abt file.
Download link
http://www.compulsivecode.com/Project_A ... mpare.aspx
