active grille shutter
hngni
Vehicle: kuga tit blue 2.0 150 2017
Post by hngni » Tue Jul 02, 2019 8:49 pm
after fitting a new active grille shutter does it have to be enabled in forscan
if so where do i find it in the forscan programe
kuga 2017 ps150
denbo
Vehicle: ford focus 16 zetec
Re: active grille shutter
Post by denbo » Wed Jul 03, 2019 8:12 am
Im not sure but it may be "plug and play" . Check power and grounds.
hngni
Post by hngni » Tue Jul 09, 2019 9:26 am
thanks
the shutter never closes fully after cold starting even after it goes through open/close motions
the main problem is slow warmup in winter time
denbo
Post by denbo » Thu Jul 11, 2019 7:01 am
Is the problem with the shutter or the sensor? Remove sensor and heat with a hair dryer. If ok fully open then do same with aerosol to cool down.See if it closes fully. Are you sure its supposed to close fully. Don,t rely on software too much. Back to basics sometimes is better.
