Using Forscan Lite to perform Regen on 2010 Mondeo
stub80
Vehicle: 2010 Mondeo TDCI
Post by stub80 » Thu Jun 27, 2019 2:05 am
Hi All
I'm trying to use Forscan lite on an IOS device to perform a DPF static regen on a 2010 Mondeo TDCI
It starts the process but then straight away says service procedure has been interrupted contact developer.
I'm using one of the Chinese ELM327 WIFI Adaptors which shows a speed of 62ms (I've tried to logon to the adaptor and change the settings as per this link viewtopic.php?f=4&t=16 but have had to luck so far)
I'm doing all this from my phone as I don't have access to a laptop at the moment.
Should you be able to perform a DPF Regen from the Forscan Lite App? If yes could the issue be that the speed is too low from the ELM to perform it
Or does it have to be done from the PC Software?
Cheers
denbo
Vehicle: ford focus 16 zetec
Re: Using Forscan Lite to perform Regen on 2010 Mondeo
Post by denbo » Thu Jun 27, 2019 7:35 am
I really do believe it has to be by pc, and not wifi.
