Transit Connect 2016 – How to enable global windows open/close ?
mbarkley
Vehicle: Ford Transit Connect, 1.5 TDCi/120PS/2016
Post by mbarkley » Wed Jun 26, 2019 4:23 pm
Hi, I try to enable automatic Windows Open/Close in my car, but I can‘ t find this option in BCM (the list ist very long).
I only found „Global open/close“ and set to the value Global open/close Doors, but I am not sure it is what I need to switch this option on for the Windows because it doesn't work, after this I try to activating windows witch the procedure:
1. Lift and hold the control until the window is fully closed.
2. Release the control.
3. Lift and hold the control again for a few seconds.
4. Release the control.
5. Lift and hold the control again for a few seconds.
6. Release the control.
7. Press and hold the control until the window is fully open.
8. Lift and hold the control until the window is fully closed.
9. Release the control.
10. Open the window and then try to close it automatically.
11. Repeat the procedure if the window does not close automatically.
but when I push the button (open or close) and hold nothing happends...
Someone knows how to fix it?
Thanks for any input.
Don Ridley
Vehicle: 2016 Transit Connect
Re: Transit Connect 2016 – How to enable global windows open/close ?
Post by Don Ridley » Wed Jun 26, 2019 11:08 pm
The vehicle must have one-touch open/close on all windows to use global open/close. This option requires door modules in each door. Your vehicle may not have this equipment.
mbarkley
Post by mbarkley » Sat Jun 29, 2019 8:50 am
Thanks for a good explanation for my question, but I hope there is another way to fix it.
Is it possible to check what kind of door modules was installed in my car under FORScan program?
BTW I am looking for a spreadsheet with codes for Transit Connect, thanks for any feedback.
