TECMULTIMARCAS
Vehicle: 2006, 4.6 , lobo, f-150
Post by TECMULTIMARCAS »
WHERE I WILL KNOW WHERE WILL OR COPY FILE TO ATTACH REQUEST FOR EXTENDED LICENSE?,
I already did it once but I can not find the log file?
Extended license doesn't require any request, you should generate it as described in the first post of this thread.
qvrths
Vehicle: Ford Falcon BA 2003 XT 4.0 Litre
Post by qvrths »
Can someone help me? I get the following error when trying to generate the key.
Generate Extended License
Unable to generate license key. Please make sure Hardware ID is copied correctly
I have copied this directly from the the ForScan Program, it is correct.
Hardware ID: 617E74DA-FFD6
There was a technical problem with server on 10 January approximately from 3:00 GMT to 18:00 GMT.
steve28157
Vehicle: ford explorer 1998 /mustang 2010
Post by steve28157 »
Hello
please help me I have a china elm327 and this has no ID
mfg steve
google translate
steve28157
Hello
After successful activation of the license
shows forsan still standard license to
and not extended license
Google Translate
steve
1. Please make sure you use the latest version of FORScan.
2. Run FORScan, go to About section and compare Hardware ID there with the one you generated the key for. If they are different, you need to generate new key,
marian_S_petre
Vehicle: Ford focus Ghia
Post by marian_S_petre »
I have a problem....I install FORScan version 2.2.11 beta for Windows (windows 7 32B) and generate new license. I made a mistake and i load my last license and now software don't want to start :( . I try to reinstall FORScan but nothing. How can i fix this?
Thank you so much.
I fix problem...Install new windows and i take another license.
Thank you Forscan
angelus.d87
Vehicle: fiesta tdci
Post by angelus.d87 »
Hello everyone, last night I made a huge mistake with a key programmer clone it, and instead of the gate.
and the car with the key not lit more ... luckily in the forum I found the license generator and I could access the PATS module, and I could encode two keys again. I must say that this program is almost on par with the original diagnosis.
I have a ford fiesta mk6 1.4tdci 2007
CLK1201
Vehicle: LEXUS RX330
Post by CLK1201 »
hello sir plase help me extended licenses for window , my id :C6DF95FB-6E3A
thanks
