adrianopery
Vehicle: Ford Ecosport 2018
Post by adrianopery »
FORScan wrote:
Fri Mar 30, 2018 9:52 am
Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
1. Protocols
Table 1.1 - Ford protocols
OBDII name / Ford name OBDII jack pinsBus speedBus min. response timeHow to detect
SAE J1850 PWM / Ford SCP2, 1041600 bps20...40 msImage
ISO9141 / Ford ISO79600 bps150...250 msImage
CAN / Ford HS CAN6, 14500 Kbps0...20 msImage
/ Ford MS-CAN3, 11500 Kbps0...20 msImage
/ Ford UBP310400 bps150...250 msImage
P - primary protocol (PCM)
GenerationSAE J1850 PWMISO 9141CANFord MS CANFord UBPComment
Ford 1996 - 2003PS---
Mazda 1996 - 2003-P---Some models used SAE J1850 PWM as primary
Ford EU, Mazda 2004 - 2009-SPS-Some models used SAE J1850 PWM as primary
Ford NA 2004 - 2009-SPSS
Ford, Mazda 2010+--PS-HS2, HS3 through MS-CAN
Focus Mk2 - only HS-CAN and MS-CANMondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN
ChipSAE J1850 PWMISO 9141CANFord MS CANFord UBPAdapter
ELM327 standardXXX--ELM327, Kiwi 3
ELM327 with HS/MS switchXXXX-ELM327 marked as Ford, Mazda compatible
STN 1100XXX--OBDLink SX/LX
STN 115xXXXX-OBDLink MX BT
STN 1170XXXX-ELS27 (old versions), Viaken STN1170
STN 2120XXXX-ELS27 (new version)
STN 2255XXXX-OBDLink MX+
STN 2230XXXX-OBDLink EX
2. Performance
AdapterChipInterfaceMin.interface
response time
Max.interface
baud rate
Comment
ELM327 OHP HS/MS WiFiELM327 (clone)WiFi30-40 ms38400 bpsUnknown manufacturer - "good clone". Recommended only for iOS
Kiwi 3ELM327 compatibleBluetooth Low Energy40 ms-Can be used only with FORScan Lite for iOS
ELM327 HS/MS USBELM327 (original)USB0..2 ms500 Kbps
OBDLink EXSTN2230USB0..2 ms2MbpsRecommended for FORScan for Windows
OBDLink SXSTN1100USB0..2 ms2Mbps
OBDLink LXSTN1100Bluetooth--
OBDLink MX+STN2255Bluetooth6..20 ms-Recommended for FORScan Lite for iOS, Android
OBDLink MX BTSTN115xBluetooth8..20 ms115200 bps
OBDLink MX WiFiSTN115xWiFi-115200 bpsWiFi interface works unstable - it freezes and times out. Strongly not recommended!
ELS27 v3STN2120USB, Bluetooth0..2 ms USB, 20 ms BT8 Mpbs USB
Viaken STN1170 USBSTN1170USB0..2 ms2 MbpsLast versions of this adpater have buggy firmware 4.3.x. Recommended to downgrade to stable 4.1.1 or upgrade to stable 4.5.1
Viaken STN1170 BTSTN1170Bluetooth20..30 ms38400 bpsUses cheap BT chip so may freeze on some cars. Not recommended
Examples:
Example 1: Ford Mondeo Mk3 PCM, bus J1850. Adapter ELM327 OHP HS/MS WiFi. According to the table 1.1, let's assume min. bus response time is 20 ms, bus baud rate is 41600 bps. According to the table 2.1 adapter's min response time is 40 ms, baud rate is 38400 bps.
Overal min.response time = 40 ms + 20 ms = 60 ms
Overal baud rate = MIN ( 38400 / 2, 41600) = MIN ( 19200, 41600) = 19200 bps.
Note: we divide interface baud rate by two because ELM327 family adapters exchange data in text format. So every machine byte is represented in 2 transferred bytes.
As we can see, the adapter significantly limits the overal system peformance in this example (in case of cars with CAN bus, like Mondeo Mk4 or Mk5, the test results would be much worse). Is that bad? Well, it depends on your goals. If reading DTC and some PIDs is the only objective you have, it is not too important. But if you plan to read PIDs in real-time (or as much close to it as possible) or perform programming (actual for CAN bus), then this adapter is a bad choice.
Example 2: Mazda 323 2001, bus ISO. Same adapter.
Overal min.response time = 40 ms + 250 ms = 290 ms
Overal baud rate = MIN ( 38400 / 2, 9600) = MIN ( 19200, 9600) = 9600 Kbps.
In this case the adapter is OK, because the bus itself is very slow. Reponse time is less than 20% higher than maximum possible for this car, and transfer speed is also limited by the bus.
Example 3: Ford Fusion 2015, bus CAN. Adapter ELS27 v3 USB. Let's assume CAN bus response time is 0 ms, and adapter has 2 ms of response time and 2 Mpbs baud rate.
Overal min.response time = 2 ms + 0 ms = 2 ms
Overal baud rate = MIN ( 2000000 / 2, 500000) = MIN ( 1000000, 500000) = 500 Kbps.
So in this case the response time is minimal, and baud rate is limtied by the CAN bus one.
3. Reliability
4. Recommendations
P - recommended for programming: complex configuration, firmware update (only for CAN )
AdapterFORScan for WindowsFORScan Lite for iOSFORScan Lite for Android
OBDLink EXD, C, PNONO
OBDLink SXD, C, P*NONO
OBDLink LXD (if MS-CAN is not required)NOD (if MS-CAN is not required)
OBDLink MX+D, CDD
OBDLink MX BTD, CNOD
OBDLink MX WiFiNONONO
ELS27 v3D, C, PNOD
Viaken STN1170 USBD, C, PNONO
Viaken STN1170 BTNONONO
* - can be modified for MS-CAN support as described here.
5. Links to original adapters
All of these adapters were tested by us.
5.1. OBDLink product line: https://www.obdlink.com/
5.2 ELS27: http://els27.ru
5.3. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
Hi guys, I would like to know if we have any other new option to use as Bluetooth device?
An updated list!
Krad79
Vehicle: 2015 f350 6.2L stock / 2016 f350 6.7L
Post by Krad79 »
Hello Everyone. just joined today. i have scanned through the threads looking and i have not seen if anybody has tried using tuner obd2 connectors for the FORScan. If someone has posted i apologies in advance for asking again.
i just downloaded and received key so i am ready to go, other then my obd2 connector.
i Have a Bully Bog bdx 40470 tuner. For my 2015 f350 6.2L crewcab longbed xlt. it has a obd2 connector to a hdmi connector. i am going to try this to see if it will work with the FORScan program, and my computer.
i believe in theory it should as it is part of a tuning program already.
i am away at work and i will try go out to my truck and see if it will connect. i will posted back with the results (good or Bad)
again if i have duplicated any previous threads ....sorry.
i will be in touch
Krad79
Update
Tested Bully dog tuner coder........ No communication....
Krad79
From the Great White North
2015 Ford F350 6.2L xlt crewcab longbed 3 inch lift 35's daily/work/hunting truck
2106 Ford F350 6.7L latriat platinum package crewcab shortbed stock/daily/campin/family ride.[/color]
gnosis
Vehicle: 2002 mazda b3000 dual sport 2WD
Post by gnosis »
So for a 2002 mazda b3000 dual sport essentially any elm is okay? Or is there one in particular that would be best?
tmittelstaedt
Vehicle: 2010 Ford Focus
Post by tmittelstaedt »
You really have 2 choices, gnosis
1) Buy one of the "supported/tested" adapters in the 3 links from the 2018 post. Those makers are very very aware of referrals from this site and they work to make their products compatible and support every option.
2) Go to Ebay and buy the cheapest ELM327 adapter possible, test it, and if it does not work return it to the seller. Then repeat with the next cheap adapter.
Right now the USB US adapter in the links in the article is on sale for $47. The cheapest clone bluetooth adapter on Ebay is $6 and the maker claims it works with the Android program Torque. The cheap adapters are frequently changed on Ebay so not only a few years from now you likely won't see the one someone bought listed, even if you do the innards will have changed.
I've bought a fair bit of ultra-cheap electronic gear from China. Let me explain how these Chinese companies work. If you buy direct from China you get the cheapest prices. Most of the time the stuff works - mostly - and if it's not going to work for you the companies have you return to a US address (on your dime of course) Then they have someone at the US address just re-list the stuff and sell it as "from a US seller" and charge more money for it of course.
I have 2 of these Chinese clone adapters. One of them was about $15 and the other around $6. Both bought years ago long before I started messing with Forscan, For the time I've wasted figuring out how to get those to work if I had to do it over again I would have bought the recommended adapter. One of those worked with Forscan to get it to do what I wanted it to do the other doesn't.
Remember that unless you are an old art-fay in your 80's you are undoubtedly not going to have your current vehicle the rest of your life. You will get future vehicles. A good Elm scantool will likely be used in the future on other vehicles so spend the money now on the good adapter and you won't have to worry about it not working in the future.
gnosis
Post by gnosis »
tmittelstaedt wrote:
Sat Dec 19, 2020 7:12 pm
Right, but is the OBDlink ex good for other vehicles as well? I was thinking of getting the OBDLINK mx+ as it's suppose to be better with mazdas (my b3000) however I don't know how well it works with Forscan compared to the ex. Also, the ex is $50 less, which is appealing in and of itself, however my understanding is that it's less compatible with other vehicles and programs...?
Also, how about a more affordable one like this:
OHP ELMconfig FORScan OBD2 Adapter - ELM327
https://www.amazon.com/gp/product/B01F0 ... ef3b1954be
rbentnail
Vehicle: 2013 F150STX 4x4 5.0
Post by rbentnail »
Here is the one I'm using with my 2013 F150 STX 5.0.
https://www.amazon.com/gp/product/B01N1 ... UTF8&psc=1
Cheap, works fine.
marekrbk
Vehicle: mondeo,qyba1e,1.8,132kw,41nm,2007 chiptunning
Post by marekrbk »
rsmith0801
Vehicle: 2008 F250 6.4L Powerstroke
Post by rsmith0801 »
I have a 2008 F250 6.4 and the OBDlink EX, it connects to the truck and says it's communicating, showing my VIN and info but never updates the modules. Just says it's communicating but no modules populate. Am I doing something wrong? One time, it did show the TCM and software date but only while I started the truck. I do have a tune but returned it to stock to see if it made a difference and no change. I also have a radio with Maestro hooked to one wire on the OBD connector. Radio was off but coukd this be affecting it?
ixxion
Vehicle: F350 PSD 6.4 2008
Post by ixxion »
Saw your post and thought I'd make my first contribution.
What are you using for a computer?
Just purchased OBDLink EX connecting without difficulty to Lenovo laptop on 2008 F350 6.4 PSD. Wish there was more I could do and test with it, but I'm pleased with what I have so far for free (extended license trial).
Now I'm looking for a bluetooth recommend just for monitoring with my android phone so I don't have to keep the laptop perched on the console ready to fall off.
LucasBS
Vehicle: New Fiesta 2014 1.6 130CV
Post by LucasBS »
I'm looking at this ELS-27 from Aliexpress.
https://a.aliexpress.com/_mKF1JsF
Is it possible to tell if it supports or not adding new keys ?
Ford New Fiesta 2014/2015
