Mondeo mk5 EU version 150KM to 180 KM, how to ?
erik vandebroek
Vehicle: ford Edge 2.0 biturbo stline
Re: Mondeo mk5 EU version 150KM to 180 KM, how to ?
Post by erik vandebroek »
silasMoses
Vehicle: Ford F150 250HP
Post by silasMoses »
Hi guys! I’ve read this topic from the beginning, and I have some questions. How to do that change of power in Ford Focus mk3.5? Are those bits location and values in PCM AsBuilt are the same as in Mondeo? In my car I don’t have such a „easy dropdown menu selection” PCM config, only what can I do in PCM is AsBuilt config. As I understood, in block 1 line 8 value must be changed from B4 to B7? Same in Focus? Anybody tried and can confirm? Second thing is change value in abs - line 760-02-01 with xxx6-xxxx-xxx0
changes to xxx7-xxxx-xxx1. Again question is that same in Focus? And at last - After all that changes, is it necessary to apply the Relearn PCM procedure or not? The same with abs recalibration? Thanks for help :)
Doki
Vehicle: Mondeo MK5, 2.0TDCI 150HP Powershift
Post by Doki »
Hi Guys,
I changed 150hp to 180hp on my Mondeo MK5 Powershift and you really can feel difference :) And fuel consumption went from 8l/100km to 6l/100km (but I will have to drive more to confirm this)
Everything was done with watching polish guy (that I don't understand) and doing what he does hahaha
Here is videos:
https://www.youtube.com/watch?v=r6V5tlrEbWk
https://www.youtube.com/watch?v=zSkPnT-glWU
(Check out his channel he has a lost mk5 mods)
He even dyno the car for a proof:
https://www.youtube.com/watch?v=ywC1RoTTQMs
Doki wrote:
Mon Jul 20, 2020 11:01 am
Hi Guys,
Here is videos:
and recommended ;)
https://www.youtube.com/watch?v=PXtnfEbEvUQ
Doki
Post by Doki »
Do you think its fine to leave stock cooler if you dont plan to beat car hard and instead drive car normally and leave it to run few minutes before turning it off after highway?
Doki wrote:
Mon Jul 20, 2020 2:12 pm
did you change the values ​​in all three modules PCM, ABS
Doki
Post by Doki »
I changed values in PCM and ABS module, nobody mentioned anything about TCM module... Can you please give me insturctions what I need to change
specko
Vehicle: Ford Mondeo mk5 150
Post by specko »
HI all.
You are mentioning here that in ABS we should change:
from: 760-02-01 with xxx6-xxxx-xxx0 -> xxx7-xxxx-xxx1
But in the youtube video, the guy changed ONLY 6 to 7, not the last letter.
What about that?
specko wrote:
Tue Jul 21, 2020 9:12 am
HI all.
What about that?
the last two digits ( checksum ) never need to be changed FORScan will do it automatically
Doki
Post by Doki »
fordsmax471 wrote:
Tue Jul 21, 2020 7:07 pm
HI all.
What about that?
What about the change in TCM module you mentioned? I read a lot about upgrade and never found any info about this...
