- Site Admin
Post
by FORScan » Sun Feb 16, 2020 10:51 am
FORScan uses binary compression and encryption to reduce the binary size and protect the code. This technique is often used by virus/malware (and often using the same compression/protection system), so some antivirus may throw a false positive if signature matched. We have created this thread to provide information on this issue.
At this moment we have this problem with FORScan v2.3.29 - several anti-virus software throw alerts for it, including Microsoft WIndows Defender. We have submitted the false positive to Microsoft and Bitdefender. Microsoft have already updated their database, so false positive should gone in the next update. They recommend to clear Defnder cache this way:
We have removed the detection. Please follow the steps below to clear cached detection and obtain the latest malware definitions.
1. Open command prompt as administrator and change directory to c:\Program Files\Windows Defender
2. Run “MpCmdRun.exe -removedefinitions -dynamicsignatures”
3. Run "MpCmdRun.exe -SignatureUpdate"
Alternatively, the latest definition is available for download here:
https://www.microsoft.com/en-us/wdsi/definitions
Bitdefender promised to check the file and update DB in next 72 hours.
JAS2006
- Vehicle: 2019 Ford F150 XLT 5.0L Supercrew
Post
by JAS2006 » Mon Feb 17, 2020 5:36 pm
Thanks for this update!
- Site Admin
Post
by FORScan » Fri Feb 21, 2020 8:35 pm
Update:
Microsoft removed trojan false positive for v2.3.29 from Windows Defender, but now it finds "PUA:Win32/Presenoker" in it
Other antivirus s/w like Bitdefender seem to simply ignore our request for EXE analysis.
Jbst
- Vehicle: Explorer ST/v6 3.0 twin turbo/2020
Post
by Jbst » Tue Feb 25, 2020 8:16 pm
So what now? Did I just waste $40.00 on a obd connector?
foden
- Vehicle: mondeo mk4 2.0tdci 140bhp 2009
Post
by foden » Wed Feb 26, 2020 7:52 pm
Jbst wrote: ↑Tue Feb 25, 2020 8:16 pm
No you should be able to add the forscan as an exception to the anti virus programs or at least allow it to run
as if the anti virus finds the false positives they should quarantine and from there you should be able to choose what you
want the anti virus to do about it i.e allow it to run
then try reinstalling forscan
hope this helps and may resolve your problem (not gauaranteed as there a lot of anti virus programs)
this worked though for me with the windows security program.
foden
Jbst
Post
by Jbst » Thu Feb 27, 2020 6:40 pm
Ok thanks. I will try that. Windows defender is my only anti virus.
yyz2pvg
- Vehicle: Ford Flex, 3.5 TC, 2015
Post
by yyz2pvg » Thu Mar 05, 2020 2:49 pm
McAfee is also providing warnings/alerts for this download.
- Site Admin
Post
by FORScan » Sun Mar 08, 2020 12:59 am
We have released v2.3.30 yesterday and tested it on Virustotal to make sure there are no false alerts. Here is the report:
- 1.jpg (277.82 KiB) Viewed 19051 times
Deejin
- Vehicle: RangerT6-MC
Post
by Deejin » Mon Mar 09, 2020 3:55 am
FORScan wrote: ↑Sun Mar 08, 2020 12:59 am
Thank you very much for your great support, I would like to confirmed, forscan V2.3.30 is no problem about that. I can install and it's working fine from now.
Best Regards,
eaa53
- Vehicle: MX5 2.0ltr 2007
Post
by eaa53 » Mon Mar 09, 2020 12:56 pm
Adaware still deletes the .exe and the shortcut on the desktop.
Added it to scan exceptions but still deletes them both automatically.
I updated Adaware software but that did not cure it either.
