Method to disable auto stop / start found
X_Kris_X
Vehicle: Ford Ecosport 1.0 Ecoboost 140KM ASB
Re: Method to disable auto stop / start found
Post by X_Kris_X » Thu Jan 09, 2020 9:00 am
semiho wrote:
Thu Oct 03, 2019 9:55 pm
Focus-MK4 wrote:
Fri May 10, 2019 3:58 pm
I wanted to try it on the new Focus 2019 but the BdyCM hasn´t the 726-48, it´s only up to 726-27
Anyone an idea?
BCM’s are quite different, so configuration byte of S&S is also different for Focus/Kuga/Escape/C-Max etc.
does anyone found the configuration byte for those models? I have the same on EcoSport (it´s only up to 726-27) :/
ted22
Vehicle: escape 2.0 2016
Post by ted22 » Sun Feb 09, 2020 3:29 pm
Any luck finding this anyone??? same on the Lincoln MKC... only goes up to 27.
Baltic
Vehicle: Ford Transit Custom 2018. 2.0 EcoB 95kW
Post by Baltic » Wed Feb 26, 2020 12:56 pm
Hello all!!
Must register to here and buy Forscan.
Is this method still valid and what those XXX are in coding? Bit confused :shock:
Transit Custom
lenko
Post by lenko » Wed Feb 26, 2020 2:24 pm
Hello all!!
Transit Custom
Still available and the X's are the positions of letters or numbers you don't touch when programming.
Baltic
Post by Baltic » Thu Feb 27, 2020 6:21 am
Ok now I get it, thanks!
Will try this when my cable arrives.
Post by fordsmax471 » Thu Feb 27, 2020 7:10 am
don't forget to backup the modules when the cable arrives ;)
https://www.youtube.com/watch?v=4Opz1oa2_n0
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro
arrgh
Vehicle: Ford Fiesta VI 1.5 95CV 2016
Post by arrgh » Mon Mar 02, 2020 12:59 am
Same here, with Focus Mk4 and Fiesta ST Mk8, BdyCM doesn't have the address mentioned, it goes only up to 726-27. BTW, I've successfully disabled the menu in the IPC, the address mentioned is present and working, menu in IPC has gone. Also tried to set the start/stop bit in APIM, but nothing changes, the start/stop is always enabled. Anyone have another BdyCM address to test? If yes, I can test it.
Fresh_1
Vehicle: 2019 Ford F150 3.5 EcoBoost
Post by Fresh_1 » Wed Mar 04, 2020 2:37 pm
Airborne_Ape wrote:
Tue Mar 07, 2017 7:17 am
BCM 726-48-02 x0xx xxxx xx
I tried it on a 2019 F-150 XLT and it appears to be working. Anyone know what this actually changed?
f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Thu Mar 05, 2020 3:48 am
Engine stop.jpg (22.68 KiB) Viewed 552 times
jejuda
Vehicle: F-150, 5.0 liter/Gasoline, 2018
Post by jejuda » Thu Mar 05, 2020 3:20 pm
Easy, Works on 2018 F-150 XL
FCIM Configuration Module
"Start/Stop Button Disable" Enable to Disable
IPC Configuration Module
"Auto Engine Shutdown with Memory" Enable to Disable
BdyCM As Built Module
726-48-02 x1xx to x0xx (first 4 digits)
