ABS Brake Bleed
tdci2009
Vehicle: Ford Focus, 1.6 TDCI 80KW, 2009
ABS Brake Bleed
Post by tdci2009 » Fri Aug 08, 2014 10:47 am
Are there any plans to include in Forscan the option "ABS Brake Bleed" for a Ford Focus 2, 1.6 TDCI, 2009?
It would be very useful when performing brake fluid flush in order to open the valves of the ABS pump so the new brake fluid can reach that area too.
Thanks.
Re: ABS Brake Bleed
Post by FORScan » Wed Aug 20, 2014 9:10 am
Yes, we are going to add these functions in future versions.
vupti
Vehicle: Mazda 6 GH, MZR-CD 2.2, 163BHP, 2009
Re: ABS Brake Bleed
Post by vupti » Wed Apr 22, 2015 6:07 am
I am interested in that option for my Mazda 6 GH 2.2 2009 year?
fred08155
Re: ABS Brake Bleed
Post by fred08155 » Wed Apr 22, 2015 7:11 am
Is this also available or will be available for Mondeo 2002 TDCI?
Would be nice to empty the ABS Block for fluid exchange. I heard there remains 1l of fluid inside.
Re: ABS Brake Bleed
Post by FORScan » Thu Apr 23, 2015 5:19 am
Yes, we plan to add ABS Bleed functions, actually it is available for some models already, will move forward with this option.
bluebear
Vehicle: ford focus 2 1.6 tdci 90 hp
Re: ABS Brake Bleed
Post by bluebear » Tue May 26, 2015 8:40 am
Can you describe the exact procedure for abs bleeding function on Ford Focus 2 2007 ?
Thanks !
Re: ABS Brake Bleed
Post by FORScan » Tue May 26, 2015 9:03 am
Not sure we understood the questions, the ABS service bleed for FF2 is still not implemented
royail001
Vehicle: ford 2.2 puma transit2006
Re: ABS Brake Bleed
Post by royail001 » Mon Jun 29, 2015 5:19 pm
is this gonna be similar to abs bleed or master bleed? program?
dj.martzian
Vehicle: Ford Focus, SHDA, 1596/74kW, 2008
Re: ABS Brake Bleed
Post by dj.martzian » Fri Oct 09, 2015 8:38 am
When this "ABS Brake Bleed" procedure will be released for Ford Focus Mk2 and Mk2.5?
Also, what are the correct steps to fallow when running this procedure, after the ESP module was replaced?
Thank you,
Cheers.
dj.martzian
Re: ABS Brake Bleed
Post by dj.martzian » Thu Dec 03, 2015 1:03 pm
Any updates? :)
