bufer
Vehicle: Focus MK3, 1.6 tdci 115 PS, 2011
Post by bufer » Mon Jun 10, 2019 10:28 am
I use this fake china UCDS Pro+ . It works with Forscan with both CAN busses (Focus MK3) without any troubless, but in case of Focus MK2 I am not able to connect vehicle.
p.s.
Solved. Problem was on the can bus of the car.
blitz456
Vehicle: Lincoln Navigator 2003
Post by blitz456 » Wed Jun 26, 2019 4:52 pm
Hi would this tool be suitable for Sp177 VCMII UBP Protocol on Forscan or do I need to get SP177C?
http://www.obdexpress.co.uk/wholesale/b ... eless.html
aroniusz
Vehicle: mondeo mk5
Post by aroniusz » Sat Jul 13, 2019 7:16 am
I am using the UCDS adapter from the Forscan (original) and it worked without problems until version 2.3.15. After upgrading to newer versions, and recently 2.3.22 you can not connect to the car. Does anyone know what could have happened? I will point out that back to version 2.3.15 and UCDS software works. The protocol I connect is J2534. Please help.
Szymon_Zy
Vehicle: Focus MKIII 1.6 tdci
Post by Szymon_Zy » Sun Aug 18, 2019 12:04 pm
If I set up J2534 connection in Forscan it still claims that elm was not found.
No ELM found. Please check connection and try again.
I'm using UCDS PRO+ and the device is listed in device manager as UCDS System (UCDS Diagnostic adapter V3 - USB\VID_0483&PID_1234&REV_0310) with driver version: 3.1.0.0
I don't see any specific to J2534 setting in configuration menu except Connection Type. Device is not listed anywhere here.
EDIT: Just installed soft from cd that came with interface and connects ok.
EDIT2: Added
- ftd2xx.dll
- libusb0.dll
- libusb0_x86.dll
- ucdsj2534.dll
to Forscan folder. It did not help.
Here are my settings. I can't chose adapter. Only bluetooth one.
actilab007
Vehicle: FOCUS CMAX 2011
Post by actilab007 » Sun Aug 18, 2019 7:09 pm
io sto usando opel mdi e funziona perfettamente molto veloce e connessione stabile
bufer
Post by bufer » Sun Sep 22, 2019 9:25 am
You must copy ftd2xx.dll, ucdsj2434.dll from UCDS to Forscan folder and it will work
