MAF sensor diagnose
Vehicle: FORD S-Max MK2 2,0TDCi PowerShift
MAF sensor diagnose
Post by fordsmax471 » Sun Feb 10, 2019 5:59 pm
Hello !
i noticed it
S-Max 2.0 TDCi 110kw
Ignition key the ON position, engine not running and MAF sensor shows 2,11 g/s
this is normal ?
Maf sensor
MAF sensor.PNG (414.66 KiB) Viewed 1261 times
ELS27 v4.0 / ELM327 v2.2 HS/MS CAN USB
Donny
Vehicle: Focus 1.6 Tdci 201071QP67
Re: MAF sensor diagnose
Post by Donny » Sun Feb 10, 2019 9:30 pm
That is not normal. It should read 0 when the engine is not running.
I don't know the exact figures for your engine, but at tick over I would expect it to be somewhere around 6 or 7 and be steady, and rise to high double figures under extreme load.
Hopefully someone with the same engine as you can confirm the normal expected values.
f-wolf
Post by f-wolf » Sun Feb 10, 2019 11:19 pm
These are the readings from a MAZDA 3 2L Petrol 2010
Ignition on Engine NOT running
Engine not running.jpg (54.45 KiB) Viewed 1245 times
And
Engine running ... Idling at about 750RPM
Engine Idling.jpg (54.5 KiB) Viewed 1245 times
Try to clean your MAF Sensor with Sensor Cleaner first ...
Post by fordsmax471 » Mon Feb 11, 2019 4:34 am
Thanks !
when the engine running 800rpm and maf 12g/s
i can't find the Forscan MAF sensor volt PID-s only MAF g/s and MAF hz
car mileage is 25000km
Post by fordsmax471 » Tue Feb 19, 2019 5:58 pm
I installed a new maf sensor today, the result is same 2.11 g/s :roll:
new maf.PNG (395.06 KiB) Viewed 1142 times
Pg502
Vehicle: Mustang, v6, 2011
Post by Pg502 » Wed May 22, 2019 1:58 am
Quick question
Can forscan via pc read the voltage from a MAF sensor ?
f-wolf
Post by f-wolf » Wed May 22, 2019 5:10 am
Yes !!
Engine Idling.jpg (55.39 KiB) Viewed 765 times
Pg502
Post by Pg502 » Fri May 24, 2019 1:56 am
So I have stalling and hesitation at idle for my 2011 mustang.
On forscan it shows g/s is around 5 and but the volts are at a constant “0”. What does that mean ? (Idle )
Pg502
Post by Pg502 » Fri May 24, 2019 1:59 am
4g/s***
WALK3R
Vehicle: Ford Trasit 2012
Post by WALK3R » Fri May 24, 2019 7:59 am
Sounds like your maf is broken, try back probing it for voltage.
