Post by FORScan » Fri Nov 16, 2018 6:27 am
We need beta-testers to test learning functions for automated transmission Powershift 6DCT450 (MPS6) on the following vehicles:
Focus Mk 3
Focus Mk 3.5
Kuga Mk 1
Kuga Mk 2
Kuga Mk 2.5
Mondeo Mk 4
Mondeo Mk 5
Galaxy/S-Max 2006-2014
Galaxy/S-Max 2015+
The function contains 2 parts: "Shift Fork System Learn" and "Clutch System Learn". It is relatively safe. It is recommended to have USB adapter for testing.
If you want to participate, please contact us via PM or email (http://forscan.org/contactus.html)
Update 2018-12-25: testing is finished.
Exo_Strike
Vehicle: F150 FX4 3.5 Ecoboost 2014
Post by Exo_Strike » Sat Nov 17, 2018 3:24 pm
I wish I have some spare times.. 2 kids! :)
I work for a ford dealer, so it's easy for me to revert back if something crash.
Are you talknig about the DSP6? In north america this transmission is called like this.
Mabye I could give a try one night.
I use a VCM2 to communicate.
Post by FORScan » Sun Nov 18, 2018 5:13 am
DPS6 is Powershift 6DCT250 with dry clutches, used on Focus and Fiesta family. Function for DPS6 learning was added to FORScan 3+ years ago:
https://forscan.org/forum/viewtopic.php?f=6&t=1672
So it doesn't require a beta testing.
MPS6 is Powershift 6DCT450 with wet clutches, used in European models: Mondeo, Galaxy, S-Max, Kuga. Actually had no chance to see MPS6 on any of models for North America, so not sure if it is used there at all.
Keithmac
Post by Keithmac » Sat Nov 24, 2018 4:06 pm
Hello, I have a MK2 Kuga 2l Powershift DCT450.
I would be interested in trying the software.
Cheers, Keith.
Jessemarkus
Vehicle: Ford mondeo 2.0 tdci 2012
Post by Jessemarkus » Wed Jan 02, 2019 7:31 pm
Clutch system learn. Mondeo MK4 Powershift 6DCT450.
I tried the test and was surprised. Previously, the gearbox changed poorly up and down with small gears. Now, after a small test drive, everything has been softer than it should be. The test ( forscan ) was frightening but at least initially excited about that.
MR42HH
Vehicle: Grand C-Max 2.0 TDCi 125 kW
Post by MR42HH » Fri Jan 11, 2019 7:33 am
Are there plans to implement the same funtion for the newer 6DCT451?
Jessemarkus
Post by Jessemarkus » Thu Jan 31, 2019 6:27 pm
Hi
What really means tcm module reset. Does the function reset the learned values?
Keithmac
Post by Keithmac » Mon Feb 11, 2019 3:52 pm
Hello, I tried this today on my Mk2 Kuga 163 Powershift 6dct450.
Both clutch and gear learns were successful!.
Thanks, Keith.
BigWolf678
Vehicle: Kuga 2.0 TDCI 2013 mk2 TitaniumX Powershift
Post by BigWolf678 » Tue Feb 12, 2019 11:22 pm
I have a 2013 mk2 Kuga which 'Thumps' when taking up drive,Genuine Oil and Filter replaced but no improvement do you think this procedure would help,im starting to get the Hump with it now !!
Andyfocus
Post by Andyfocus » Tue Feb 12, 2019 11:40 pm
i would try it cant hurt as long as you follow the instructions , if it doesnt then i would start suspecting something mechanical or a fault with the anti wheel spin / anti locking sytem , not sure what its called or if it uses the same system to detect when the wheel looses grip , would suspect it does but dont know for sure sorry .
