Post by FORScan » Fri Mar 30, 2018 9:52 am
Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
1. Protocols
Table 1.1 - Ford protocols
OBDII name / Ford name OBDII jack pinsBus speedBus min. response timeHow to detect
SAE J1850 PWM / Ford SCP2, 1041600 bps20...40 msImage
ISO9141 / Ford ISO79600 bps150...250 msImage
CAN / Ford HS CAN6, 14500 Kbps0...20 msImage
/ Ford MS-CAN3, 11500 Kbps0...20 msImage
/ Ford UBP310400 bps150...250 msImage
P - primary protocol (PCM)
GenerationSAE J1850 PWMISO 9141CANFord MS CANFord UBPComment
Ford 1996 - 2003PS---
Mazda 1996 - 2003-P---Some models used SAE J1850 PWM as primary
Ford EU, Mazda 2004 - 2009-SPS-Some models used SAE J1850 PWM as primary
Ford NA 2004 - 2009-SPSS
Ford, Mazda 2010+--PS-HS2, HS3 through MS-CAN
Focus Mk2 - only HS-CAN and MS-CANMondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN
ChipSAE J1850 PWMISO 9141CANFord MS CANFord UBPAdapter
ELM327 standardXXX--ELM327, Kiwi 3
ELM327 with HS/MS switchXXXX-ELM327 marked as Ford, Mazda compatible
STN 1100XXX--OBDLink SX/LX
STN 115xXXXX-OBDLink MX BT
STN 1170XXXX-ELS27 (old versions), Viaken STN1170
STN 2120XXXX-ELS27 (new version)
STN 2255XXXX-OBDLink MX+
STN 2230XXXX-OBDLink EX
2. Performance
AdapterChipInterfaceMin.interface
response time
Max.interface
baud rate
Comment
ELM327 OHP HS/MS WiFiELM327 (clone)WiFi30-40 ms38400 bpsUnknown manufacturer - "good clone". Recommended only for iOS
Kiwi 3ELM327 compatibleBluetooth Low Energy40 ms-Can be used only with FORScan Lite for iOS
ELM327 HS/MS USBELM327 (original)USB0..2 ms500 Kbps
OBDLink EXSTN2230USB0..2 ms2MbpsRecommended for FORScan for Windows
OBDLink SXSTN1100USB0..2 ms2Mbps
OBDLink LXSTN1100Bluetooth--
OBDLink MX+STN2255Bluetooth6..20 ms-Recommended for FORScan Lite for iOS, Android
OBDLink MX BTSTN115xBluetooth8..20 ms115200 bps
OBDLink MX WiFiSTN115xWiFi-115200 bpsWiFi interface works unstable - it freezes and times out. Strongly not recommended!
ELS27 v3STN2120USB, Bluetooth0..2 ms USB, 20 ms BT8 Mpbs USB
Viaken STN1170 USBSTN1170USB0..2 ms2 MbpsLast versions of this adpater have buggy firmware 4.3.x. Recommended to downgrade to stable 4.1.1 or upgrade to stable 4.5.1
Viaken STN1170 BTSTN1170Bluetooth20..30 ms38400 bpsUses cheap BT chip so may freeze on some cars. Not recommended
Examples:
Example 1: Ford Mondeo Mk3 PCM, bus J1850. Adapter ELM327 OHP HS/MS WiFi. According to the table 1.1, let's assume min. bus response time is 20 ms, bus baud rate is 41600 bps. According to the table 2.1 adapter's min response time is 40 ms, baud rate is 38400 bps.
Overal min.response time = 40 ms + 20 ms = 60 ms
Overal baud rate = MIN ( 38400 / 2, 41600) = MIN ( 19200, 41600) = 19200 bps.
Note: we divide interface baud rate by two because ELM327 family adapters exchange data in text format. So every machine byte is represented in 2 transferred bytes.
As we can see, the adapter significantly limits the overal system peformance in this example (in case of cars with CAN bus, like Mondeo Mk4 or Mk5, the test results would be much worse). Is that bad? Well, it depends on your goals. If reading DTC and some PIDs is the only objective you have, it is not too important. But if you plan to read PIDs in real-time (or as much close to it as possible) or perform programming (actual for CAN bus), then this adapter is a bad choice.
Example 2: Mazda 323 2001, bus ISO. Same adapter.
Overal min.response time = 40 ms + 250 ms = 290 ms
Overal baud rate = MIN ( 38400 / 2, 9600) = MIN ( 19200, 9600) = 9600 Kbps.
In this case the adapter is OK, because the bus itself is very slow. Reponse time is less than 20% higher than maximum possible for this car, and transfer speed is also limited by the bus.
Example 3: Ford Fusion 2015, bus CAN. Adapter ELS27 v3 USB. Let's assume CAN bus response time is 0 ms, and adapter has 2 ms of response time and 2 Mpbs baud rate.
Overal min.response time = 2 ms + 0 ms = 2 ms
Overal baud rate = MIN ( 2000000 / 2, 500000) = MIN ( 1000000, 500000) = 500 Kbps.
So in this case the response time is minimal, and baud rate is limtied by the CAN bus one.
3. Reliability
4. Recommendations
P - recommended for programming: complex configuration, firmware update (only for CAN )
AdapterFORScan for WindowsFORScan Lite for iOSFORScan Lite for Android
OBDLink EXD, C, PNONO
OBDLink SXD, C, P*NONO
OBDLink LXD (if MS-CAN is not required)NOD (if MS-CAN is not required)
OBDLink MX+D, CDD
OBDLink MX BTD, CNOD
OBDLink MX WiFiNONONO
ELS27 v3D, C, PNOD
Viaken STN1170 USBD, C, PNONO
Viaken STN1170 BTNONONO
* - can be modified for MS-CAN support as described here.
5. Links to original adapters
All of these adapters were tested by us.
5.1. OBDLink product line: https://www.obdlink.com/
5.2 ELS27: http://els27.ru
5.3. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
dickiefrank
Vehicle: 2103 Ford F150 STX 5.0
Post by dickiefrank » Sun Jun 03, 2018 1:42 am
I'm getting a reading on the forscan when I try to link it to the truck...says "bad clone"...my connector does not have the toggle switch...am I to conclude that I need the one WITH that toggle switch?
Vladsky
Vehicle: 2017 Ferd PHEV
Post by Vladsky » Sun Jun 03, 2018 12:22 pm
dickiefrank wrote:I'm getting a reading on the forscan when I try to link it to the truck...says "bad clone"...my connector does not have the toggle switch...am I to conclude that I need the one WITH that toggle switch?
The proper adapter you need is already specified above.
Suggest you start reading, Dickie :lol:
Vlad
nixoid
Vehicle: Ford Ranger, 4.0 liter, 2003
Post by nixoid » Sat Jun 09, 2018 4:13 am
Vlad
I haven't looked at too many threads yet but every post I've seen from you has the voice of a troll. Instead of just telling people to read like they're stupid or lazy, try helping out. Not everyone can understand technical info as well as you.
Scott2373
Vehicle: F150, 2.7TT/2018
Post by Scott2373 » Wed Jul 04, 2018 8:11 pm
Thank you for this excellent info, from this noob! Hopefully I can understand all of this, because there are several changes I'd like to make to the factory settings! Thanks again!
Johnny641
Vehicle: F-150 3.5L Ecoboost 2015
Post by Johnny641 » Tue Jul 17, 2018 2:58 am
I will choose this adapter for my F-150 xlt 2015 3.5 EB, i guess that will be fully compatible with Forscan and my truck?
https://www.amazon.com/VINT-TT55502-ELM ... B01N18TOFB
Tell me if i'm wrong
Johnny641
ryanynh
Vehicle: 2014 Ford Fusion Titanium 2.0 GDTI AWD
Post by ryanynh » Wed Jul 18, 2018 1:34 pm
Johnny641
I have that exact adapter and have used it on my 14 Fusion to make some mods as well as my 15 F-150 & the kids’ 07 Fusion. Works great. Only thing I dislike is the setup instructions weren’t fantastic and I forget which side of the switch is the MS Can and HS Can.
mquick5
Vehicle: 2017 Ford Expedition Xlt El 3.5l turbo*2006 Roush
Post by mquick5 » Mon Oct 01, 2018 11:52 pm
I ordered same one today. Hopefully I can figure out how to get the right forscan so I can make program changes.
ryanynh
Post by ryanynh » Wed Oct 03, 2018 10:50 pm
I Replied to your PM about the driver download. Depending what you want to do, there is a lot of info on the various forums on the different mods. In a few cases, I was able to get a list of mods and the "code" in an excel spreadsheet so I knew exactly what I wanted to do (such as setting Bambi mode and changing the heated seat & wheel temps).
mquick5
Post by mquick5 » Thu Oct 04, 2018 2:49 am
Ty, I have a 2017 Expedition xlt el 4x4. No heated seats. I do like the bambi mode idea. Also I want to enable the fogs to drl, & drive in movie mode on the stereo, as well as the lane change # of flashes. Really was hoping for tps monitor on dash, & maybe boost gauge but no luck with those so far.
