SCCM not showing
valkman
Vehicle: 2013 Ford Focus ST
SCCM not showing
Post by valkman » Fri Jun 29, 2018 12:31 pm
hey guys.
I have been looking for an answer for this for the last 4 days, but I cant find any
I have a 2013 ford focus ST, and I want to be change the number of the turn signals flashing when "tapping" the turn signal lever.
I was able to find out that it can be changed under the SCCM (stearing column control module) option
but for the life of me, when I connect to forscan (lastest version) with the MS/HS ELM connector, that module does not show up at all in the list
I tried different usb ports, nothing, disconnect and reconnect, nothing, reboot the laptop, nothing
so I am sure there is a way to get that SCCM to show up
any help is greatly appreciated
thanks
JboyJohnny
Vehicle: F150,5.0,2015
Re: SCCM not showing
Post by JboyJohnny » Wed Jul 04, 2018 6:42 pm
2015 5.0 XLT Sync 2
Im having the same issue.
Does anyone have any ideas?
JboyJohnny
Post by JboyJohnny » Wed Jul 04, 2018 7:39 pm
Ok so I figured it out.
I hope your adapter has the MS/HS switch, if not this is probably of no value to you.
Go into forscan.
Go to settings and make sure under ELM327 specific that the HS/MS switch option is selected.
Also if it asks you to load your profile select no.
I could type a million words explaining how to do it but if you watch the first 3 mins of this video youll see exactly what to do to make all those modules appear.
https://www.youtube.com/watch?v=IhhF7iNAEAg
I hope this helps!
valkman
Post by valkman » Mon Jul 09, 2018 4:48 pm
not showing still
enabled hs/ms under connection (not auto)
not showing sccm
something is blocking this module form showing. If I can just know what it is.
I know its not a setting setting in forscan, otherwise it would have showed by now
I have been trying this for a whole week now, and nothing..
anyone came across this and fixed it?
thanks
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Mon Jul 09, 2018 6:35 pm
Has it actually got one?
valkman
Post by valkman » Wed Jul 11, 2018 8:05 pm
i am wondering the same...
i mean there has to be a way to change the number of blinks when you tap the turn signal lever.
if sccm is not there, how else to change the number? for a 2013 focus st?
