Disable mykey
Hiwa
Vehicle: fusion 2017 2.5L
Disable mykey
Post by Hiwa » Thu Jul 05, 2018 11:36 am
Hello Dears,
appreciate if you could help me to disable Mykey on my Ford Fusion 2017 while I just have a single key. so is there any way to disable it via Elm327.
f-wolf
Vehicle: *** Ford ***
Re: Disable mykey
Post by f-wolf » Thu Jul 05, 2018 12:06 pm
How do you turn off MyKey on Ford?
Use the information display and follow these steps:
Switch the ignition on using an admin key or fob.
Access the main menu on the information display controls and select Settings, then MyKey by pressing OK or the > button.
Use the arrow buttons to get to a feature.
Press OK or > to make a selection.
https://www.google.com.au/search?q=how+ ... e&ie=UTF-8
Hiwa
Re: Disable mykey
Post by Hiwa » Thu Jul 05, 2018 1:52 pm
Thank you for your kind reply. But for doing these steps need to have both keys admin and FOB and I only have a single key. I don’t want to issue another key. If there is a solution for fixing it by ELM327 would be amazing.
f-wolf
Re: Disable mykey
Post by f-wolf » Thu Jul 05, 2018 11:57 pm
shevchukw
Vehicle: 2017 f150 2.7
Re: Disable mykey
Post by shevchukw » Thu Jul 12, 2018 3:49 am
i have forscan version 2.3.15 and i cant get to the screen where it gives you option to change engineering 1 or 2 etc. i need to remove MYKEY to remove my speed limiter. i know its under option in BCM 720-02-01 but i can only access starting 726-xx-xx. i do the the extended licence also. how do i get here???
2015 f-150 3.5 ecoboost
workas
Vehicle: Ford Mustang 3.
Re: Disable mykey
Post by workas » Thu Jul 11, 2019 9:50 am
my key function is in ICM
truark21
Vehicle: 2016 Ford Fusion SE
Re: Disable mykey
Post by truark21 » Fri Jul 12, 2019 2:37 pm
I believe you mean IPC? The IPC modules start with 720
sanchezadann
Vehicle: 2014 Ford F150 3.7L V6 Flexfuel
Re: Disable mykey
Post by sanchezadann » Wed Jul 17, 2019 9:10 pm
Here is the link to the post I created on how to remove mykey viewtopic.php?f=16&t=10230
TimFor
Vehicle: Ford Focus, 1,8 TDCI, 85kW, 2007.
Re: Disable mykey
Post by TimFor » Fri Aug 09, 2019 6:15 pm
This topic is a duplicate of viewtopic.php?f=5&t=4622.
Please search before posting.
sanchezadann
Re: Disable mykey
Post by sanchezadann » Fri Aug 09, 2019 10:20 pm
Duplicate of viewtopic.php?f=5&t=4622.
No it’s not. So “please do ur fucking research idiot” that’s not a duplicate. That’s just what I did. I didn’t use their topic bc I and so many others couldn’t understand it so I made my own
