Mondeo MK5 EPB
Porter24
Vehicle: ford focus ST 2011 2.5
Mondeo MK5 EPB
Post by Porter24 » Fri Jan 20, 2017 7:08 pm
Hello i have a 2015 mk5 mondeo or fusion in the states that has an electronic parking brake can this be rest or put into service mode using forscan? Any help appreciated
flo3flo
Vehicle: Ford Mondeo 2.0 diesel 2015 Titanium X pack
Re: Mondeo MK5 EPB
Post by flo3flo » Sat Jun 30, 2018 12:42 pm
I need to do this also......
Did you ever figure out how.
Thanks.
f-wolf
Re: Mondeo MK5 EPB
Post by f-wolf » Sat Jun 30, 2018 1:07 pm
On 2013 and newer Ford Fusion models, the parking brake uses rear calipers with electric motors to actuate the electronic parking brake (EPB). Putting the system into service or maintenance mode to retract the pistons is performed using a series of steps while sitting in the driver’s seat.
http://www.brakeandfrontend.com/electro ... -vehicles/
How to put your rear brakes into service mode
https://www.youtube.com/watch?v=52YNa1_PCTU
flo3flo
Re: Mondeo MK5 EPB
Post by flo3flo » Sat Jun 30, 2018 2:56 pm
Unfortunately this sequence does not work on my Mondeo MK5 2015. (sync 2 version)
I've tried numerous times but nothing happens.
I therefore assume I need to do this....
https://youtu.be/Sb8vmjGTwkU
thanks though.
flo3flo
Re: Mondeo MK5 EPB
Post by flo3flo » Sun Jul 01, 2018 3:05 pm
It can be done using Forscan
In the 'service procedures' tab there is a function called 'Enter electric parking brake maintenance mode'
A message then pops up,.....
'This procedure puts the module into the service position for changing brake pads or calipers. The calipers will be retracted and locked in place so the brake pads can be replaced. No other command can be used other than Exit Maintenance Mode at this point.'
There seems to be an issue with my car though. When i start the above task it aborts with a message saying,
'ensure the parking brake is applied' which it is, so not sure what is going on.
Hopefully there will be a Forscan developer online here soon, to help me out with this.
PS. Absolutely no faults or problems found during DTS scan.
cheers
denbo
Vehicle: ford focus 16 zetec
Re: Mondeo MK5 EPB
Post by denbo » Sun Jul 01, 2018 7:41 pm
That doe,s not seem right! How can they retract with parking brake "on" When i do VW parking brake it insists on battery backup or charger connected. Do not open any doors etc until finished.
flo3flo
Re: Mondeo MK5 EPB
Post by flo3flo » Mon Jul 02, 2018 1:20 pm
Not required on a Mondeo as shown in the videos above.
tdcisteve
Vehicle: mk5 mondeo 2.0 tdci 180 hp 2015
Re: Mondeo MK5 EPB
Post by tdcisteve » Thu Aug 02, 2018 6:41 pm
I do have the same issue on my 2015 Titanium 2.0 TDCI with manual shift as discribed by flo3flo.
Car doesn't react on the manual switch sequence in the video"s and fails the Forscan Maintenance mode :cry:
Can anyone help me out ??
tdcisteve
Re: Mondeo MK5 EPB
Post by tdcisteve » Sun Aug 12, 2018 10:03 am
Got my Mk5 in brake maintenance mode by try and error...
Found out that the parkingbrake has to be off before starting the task, the forescan 2.3.16 program mentions; be sure to have the parking brake set.
Please check if this fault can be corrected in the program. ;)
jon67
Vehicle: Mondeo MkV
Re: Mondeo MK5 EPB
Post by jon67 » Mon Aug 20, 2018 3:52 pm
I have the latest version of Forscan which is installed on my laptop and there is no brake maintenance mode option when connected to my 2015 Mondeo 2.0 tdci.
