Configuration for Kuga 2017 with Sync3
Re: Configuration for Kuga 2017 with Sync3
Hi to all,
take a look at this viewtopic.php?f=16&t=5701#p20264
Maybe someone can be interested.
Regards.
Regards.
work on sync 3 2018???????????
thanks
1) I changed to classics theme because it is colorful comparing to timeless
7D0-03-01: xxxx 00xx xxxx - Ford Classics theme
7D0-03-01: xxxx 01xx xxxx - Ford Timeless (default)
2) Following setting is working in my kuga 2017..
7D0-01-02: xxxx x3xxx xxxx - Climate button + climate voice control
7D0-04-01: xxxx xxx0 xxxx - To see set temperatures on main screen (shortcut to climate setting window is climate button enabled)[/quote]
thanks
for Ecosport?
I think you must try by yourself or search for other's experience.
for Ecosport?
hilskg wrote:Hi,
for Ecosport?
now i have bought a obd interface and i'm waiting to come. i will try but i wanted an opinion,after verification I will announce on the forum what can be done
your approach is correct, but this topic is for Kuga 2017.
Search and write to or open a specific topic for your car...this is a more correct approach...
By the way, for give you an opinion, the correct parameters/values differ from car to car (even for different generation of the same car) and then the only solution is to try by yourself what is working for your car or use what is discovered by other user on the same car.
Hope this help you.
Hope this help you.
thank you for the advice ,but sync 3 is sync 3 and no one has ecosport, and I'm looking for something similarlskg wrote:Hi,
Hope this help you.
have a nice day
i solved problem
hello guys:
Can forscan update Sync3 2.3 to Sync3 3.0 ?
I have an issue while update to Version 3.0 by using thumb USB drive.
https://imgur.com/a/bqd5j
[quote="ROH"]hello guys:
https://imgur.com/a/bqd5j[/quo
is posible look for youtube as examples,but not with forscan
you have to go to the ford with the car series and see if updates are available,only for your car
Hi ROH,ROH wrote:hello guys:
updating firmware of Sync 3 has nothing to do with Forscan and then this is not the correct forum for your issue.
By the way, your issue is maybe caused by incorrect unzip of update pack in the usb thumb or something similar.
You added klimate to your sync 3, do you have issue when ussing
Navigation and then look to your guide on your cluster?
Is the guide correct?
Joé
Joé
