seems to hang waiting for a response
I have a 2018 f150
I have been trying to use forscan so I can enable sub woofer output and a few other things.
When I connect to the truck everything seems to be ok, the problem starts when Forscan asks to enable ms switch position.
after enabling m,s Forscan detects 1 more module "IPMB" then just sits there like it is waiting for a response but not getting one.
at this point the light on the obd adapter just flashes but nothing happens.
I'm not sure if this is user error on my part or an issue with my setup.
I have tried 2 dongles one is usb (ch340) and the other is Bluetooth.
If necessary I will get a different dongle but I just want to make sure I'm not missing something first.
I have tried both windows 10 and windows 7 (same laptop with extended license)
The key is in the on position but truck is not running.
any idea what I am doing wrong?
Thanks,
I have a 2018 f150
Thanks,
- truckfor.PNG (95.51 KiB) Viewed 7320 times
Re: seems to hang waiting for a response
Anybody solve this, I have the same issue!! Thanks
This worked for me on a bbfly pro Bluetooth
In connection “Bluetooth”
Only option to select after “MS-CAN SUPPORT “auto” and MS-CAN support “Share with HS CAN”
Please send FORScan debug info to support for investigations (PM here or email ). Instruction is on Contact Us page of the main site.
I tried changing to "share with hs can" but no difference.Robiaman wrote:This worked for me on a bbfly pro Bluetooth
Thank you for the suggestion though.
logs sent thanksFORScan wrote:Please send FORScan debug info to support for investigations (PM here or email ). Instruction is on Contact Us page of the main site.
Thank you FORScan support for your help, it is much appreciated.
Turns out the fix was pretty simple. When FORScan would sit and wait for the IPMB module I just had to power off the ignition for 5-6 seconds then turn back to on position.
This cleared the issue with IPMB and allowed FORScan to read all modules as it should.
Sticked this thread as the problem seems to be actual for IMPB of newest (2018 MY) cars, and the only workaround that really works is the one Milk_Man found:
This seems to be a bug in the IPMB module firmware. We will try to implement a workaround by removing a request that causes the hanging, but so far there is no confidence it will help as other requests may fail too.
This has to be done only once, during the first connect after the vehicle profile is removed.Milk_Man wrote: Turns out the fix was pretty simple. When FORScan would sit and wait for the IPMB module I just had to power off the ignition for 5-6 seconds then turn back to on position.
- Vehicle: mazda3 axela,SKYACTIV-G 1.5L/117Ps,2016
I have the same problem..
- Vehicle: F150, 2.7L Ecoboost, 2019
I am having the same problem but the simple fix of turning the ignition off for 5-6 sec and turning it back on doesn't work. Does anyone have any other suggestions or is there a nuanced step in the process that I am missing? Any help would be very much appreciated.
- Vehicle: Ford F150 2.7l ecoboost 2015
I have a similar issue with my 2015... I have discovered that if I decline to load the profile already in forscan it will continue to connect and then ask about using a profile again later in the process.
