Have you looked at this thread?
One of the first things it says is:
FORScan wrote:This article describes PATS programming procedure. The article is actual for version 2.3.8 (PATS programming is implemented for Ford, Mazda, Lincoln and Mercury models approximately of 1997-2011 model year, depends on model and market). If PATS programming functions is not available in the list of service functions, it means it is not implemented for this model. If the PATS programming function is available in the Service chapter, it is implemented for this model and must work in full.
Note in particular these parts:
So if you don't see a "PATS programming" option in the service menu then your 2013 vehicle probably isn't supported.
Of course it also says:
I do have the PATS programing option, but when I try to use it it says my 2011 car is not supported.
So much for it must work in full...
