Known problems with china clones of ELM327
welbo
Vehicle: Ford Expedition 5.4L 2005
Re: Known problems with china clones of ELM327
Post by welbo » Sun Dec 11, 2016 1:54 pm
My clone of the ELM 327 worked initially. Before I modified it, it reported information off of the HS CAN bus and OBD data. After my initial modification, it reported MS CAN information as well. However the switch I used was too big so I changed it to a smaller switch and now Forscan reports it is a "Bad clone" and it does not work at all. The 'AT' commands listed in this post all return non-error results. The pins and wires have proper continuity from the connector to the PIC chip controller when tested with a meter, in both switch positions.
I think my modification must be the first change to look at. Is there a specific 'AT' command or test I can do to confirm communication with the MSCAN or HSCAN bus? Is there a way to bypass Forscan's proclamation that it is a bad clone so I can continue to test it?
welbo
Post by welbo » Wed Dec 14, 2016 2:08 pm
I rewired my ELM327 clone modification and the unit works properly now. Forscan only returns one unknown command in the log. Is there any way to tell which command is unknown?
Pendaws
Vehicle: Ba Falcon 4.0 ltr 2003
Post by Pendaws » Mon Feb 13, 2017 11:06 am
Hi there, I am a new member of this forum and would like to ask a question regarding these cheap units.
I got one and it was a WiFi one but, when I linked to it from my laptop, it found the unit okay but won't function
with Forscan, I tried 2.36beta, 2.25beta and 2.28beta but each time ended up with the same response from FORscan.
I am going to return this unit and am looking at getting another unit through Ebay that is said to be for Aussie cars.
I have a 2003 BA Falcon and just want to programme my keys for it and this cheapie one isn't going to do it so,
will this USB one from Ebay be a better buy? it says it has been modified and is for Ford/Mazda.
Any help would be much appreciated.
Problem with cheapie
Aussie one, worth buying?
duytshz
Vehicle: Ford Focus,2.0L/114kw,2010
Post by duytshz » Sun Feb 19, 2017 6:29 pm
Pendaws wrote:Hi there, I am a new member of this forum and would like to ask a question regarding these cheap units.
I buy in the store, the quality is very good https://item.taobao.com/item.htm?spm=a2 ... t=1#detail
sbisson_117
Vehicle: Ford Focus 2011(US) SE 2.0L
Post by sbisson_117 » Wed Feb 22, 2017 4:39 am
I just got this one, will let you know how it goes.
http://www.ebay.com/itm/272026924589
SoNic67
Vehicle: Mercury Sable, 3.0L DOHC, 2001
Post by SoNic67 » Sun Feb 26, 2017 4:24 pm
I agree with the first post. I have bought two adapters some years ago and they work great still.
Starting with last year I keep trying to buy another adapter, tried 4 different types, and none of them cannot read Ford protocols anymore. Some might work in a Hyundai Sonata (ISO protocol), but with issues (not reading all the sensors correctly, like the MAF).
1995E
Vehicle: 2013 Fusion Titanium, 2014 F-150, 2011 Explorer
Post by 1995E » Tue Mar 14, 2017 3:29 am
I have an ELM327 I just bought that uses bluetooth only and it keeps stopping when FORscan tries to read the ACM module. It read it successfully once. I was able to change a few parameters but now it keeps crashing when trying to read the ACM and will not initiate module programming anymore. :( I only had this thing for 2 hours. Is there a link to reliable ECM327 sellers? Or should I just buy an OBDLink MX? Thanks!
Nevermind, solved my own issue by buying an OBDLink MX bluetooth. I should have looked at this post before buying a bluetooth ELM327.
A note here: Don't buy the OBDLink MX wi-fi as some buddies of mine said it's barely working with FORscan for them. I highly recommend the OBDLink MX bluetooth and directly from the manufacturer.
Maca
Vehicle: Mazda 3 BK 2008 2.0 Petrol
Post by Maca » Sun Apr 30, 2017 5:08 am
I wrote a ELM327 tester that cycles through most of the commands to see what works.
There are some commands that are not tested but should give a good indication on what commands are available.
Although it might be fine (perhaps someone with more experience than I can answer), please do not run while attached to a car. This means that only certain USB connected devices should be tested for now.
Youtube Video of the software working -> https://youtu.be/ADl7YvnIY-I
ELM327 Tester download link -> https://www.dropbox.com/sh/t6jdm6b27yrz ... LGb4a?dl=0
Patata
Vehicle: Ford Focus 1.8tdci 115cv, 2003
Post by Patata » Tue May 09, 2017 8:42 am
Hi. What Elm327 will be better the PIC18f2480 or 18f25k80? I want to use this with Focus mk1 tdci. Regards
Chasen
Vehicle: ford focus 2014
Post by Chasen » Mon Jul 17, 2017 6:42 am
China ELM327 Vgate Scan Advanced OBD2 Bluetooth Scan Tool(Support Android And Symbian) Software V2.1
http://www.uobdii.com/wholesale/elm327- ... -tool.html
